    MMM-CalendarEXT: Not Showing Latest Private Google Calendar Feed
    12 Posts 5 Posters 5.8k Views 4 Watching
      cccp402
      Hello Everyone,
      I’ve been searching for a way to resolve my experience, and haven’t found anything yet. The MMM-CalendarEXT instance on my magicmirror is not displaying updated events from my google calendar.
      When I download and review the ics data, I’m seeing what is matching on the google calendar, however it is not what is showing when the magicmirror is running. At first I thought this was a caching issue, but I’ve reset the private calendar link in google - presuming that it would pull a new file - and it still shows old (original prior to the event update) information.
      I’m probably missing something, so wanted to reach out and ask the community.
      Thanks in advance…
      S ? 2 Replies Last reply Reply Quote 0
        sdetweil @cccp402
        @cccp402 the calendar must be public, as mm is not logged on as you.
        Your desktop browser IS logged on as you
          cccp402
          So, I can’t use the Secret address from google? Sorry if I wasn’t clear, that is the address I was using to get the ical file to confirm the difference between events.
          Would rather not make this particular calendar public.
          Thanks again
            robiv8
            Correctly identified,
            if someone puts out a code with which you can sign up as a google user, that would be great.
              A Former User @cccp402
              @cccp402
              For MMM-CalendarExt(not MMM-CalendarExt2), check redrawInterval of system parts and interval of calendar parts in configuration.
              https://github.com/eouia/MMM-CalendarExt/wiki/Configuration
                cccp402 @Guest
                @sean Great, I’ve adjusted those values, and will see if that addresses what I’m experiencing.
                Is there a cache of the previously accessed ics file somewhere in the system? I am still seeing the old version of the calendar, prior to the event modifications.
                  @cccp402
                  There is no cache.
                  Can you share the .ics URL to examine details? My email is eouia0819@gmail.com.
                    anthony6608 @Guest
                    @Sean Hi, something is definitely wrong with the default calendar module. It worked for me when I installed a few weeks ago but recently I did a fresh install and noticed the calendar displays "No upcoming events’ no matter ics file or url I use. Public URLS and my own ICS work using other methods and definitely have data populated but the mirror/module shows "No upcoming events’ no matter what. Actually tomorrow is presidents day and still nothing. Could you please check into this for us? Thanks.
                      sdetweil @anthony6608
                      @anthony6608 the default holiday Cal only had 2017 & 2018 holiday events.
                      There is a new one for 2019. Just posted earlier today in one topic
                      See https://forum.magicmirror.builders/post/52595
                      Also, open the dev console
                      npm start dev
                      And look for errors in the console tab
                        A Former User @anthony6608
                        @anthony6608
                        Are you talking about my module (MMM-CalendarExt) or default calendar module? I’m slightly confused.
                          anthony6608 @Guest
                          @Sean Sorry, referring to the default calendar. Now I notice my MM is complaining about addr/port already In use. Do you know anything about troubleshooting that error?
                            u have to stop the MM instance before starting the debug instance… can’t run two at the same time
