    CalDAV with Synology
    4 Posts 2 Posters 2.4k Views 3 Watching
    • K Offline
      kayle
      Re: ICS calendar not working (Synology NAS)
      Hi everybody,
      did anybody managed to get CalDAV working between Synology NAS Calendar and MM2 ? The problem is that the synology nas calender does not provide an ics file. The link I got from my synology works perfectly in thunderbird calendar app, but not on the mirror.
      Any tips?
      Kind Regards
      Kay
      • K Offline
        kayle
        I got it. For those who have the same problem:
        You have to export your calendar as ics file. That can be done automatically if you set the Url in your module to:
        http://:@/caldav//xxxx?export
        You need the Thunderbird caldav link and add the ?export behind it. That’s all.
        Kay
        • F Offline
          fischphob
          Hi Kay,
          I’ve exactly the same problem, but can still not solve it with your proposed URL (&export).
          The Thunderbird and the Max OS links are working fine.
          The Thunderbird link is as follows (server name replaced by localhost):
          https://localhost:5001/caldav/micha/home/
          So, I assume I have to use
          https://localhost:5001/caldav/micha/home&export
          But that doesn’t work.
          So I varied the link with localhost, 127.0.0.1, my public dyndns address, with and without &export
          Nothing helps.
          Can you help me with that? Could https be a problem?
          Best regards,
          Michael
          • F Offline
            fischphob
            Ok, I solved it temporarily by using unencrypted http and port 5000.
