    Back to Booting to black
    13 Posts 2 Posters 4.2k Views 2 Watching
      dwleo
      Re: MM booting to black
      Well, all was going pretty good. I added some modules and removed some. Had Carousel, NHL and NFL working well. Almost.
      Then I changed the Calendar to another module, didn’t like the look so went back to calendar and everything went into the toilet. It was booting to black so I went back into it from my laptop and checked the config.js file and could not find an error. Copied it to Jshint and it gave this:
      One undefined variable
      111 module
      That was in the last line:
      if (typeof module !== “undefined”) {module.exports = config;}
      But that is the same in the sample and my backup.
      So I deleted the config.js and renamed the backup as config.js. No change.
      I stopped the process with:
      pm2 stop all and got:
      │ Name │ mode │ status │ ↺ │ cpu │ memory │
      │ MagicMirror │ fork │ stopped │ 0 │ 0% │ 0 B │
      I ran npm config:check and got:
      pi@raspberrypi:~/MagicMirror/config $ npm run config:check
      magicmirror@2.6.0 config:check /home/pi/MagicMirror
      node tests/configs/check_config.js
      Checking file… /home/pi/MagicMirror/config/config.js
      Your configuration file doesn’t contain syntax errors :)
      So now I am not sure which direction to go.
        start the MM in debug mode
        npm start dev
        then select the console tab… look for errors (red text)
        altho usually black screen is caused by failures in the node modules
        so, minimze MM, alt-spacebar, n
        and look at errors in the console window (used above for npm start
          dwleo @sdetweil
          pi@raspberrypi:~ $ npm start dev
          npm ERR! missing script: start
          That’s what I got.
            sdetweil @dwleo
            @dwleo well, you have to be IN the MM folder
            cd MagicMirror
              dwleo @sdetweil
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘moment-timezone’
              D S 2 Replies Last reply Reply Quote 0
                dwleo @dwleo
                Sometimes I feel like a real noob. Anyway the config.js file is there right where it always has been.
                  sdetweil @dwleo
                  @dwleo
                  from the MM folder run
                  and work thru the errors from top to bottom
                  rerunning as needed
                    sdetweil @dwleo
                    @dwleo yes, but there is a syntax error from all the editing you have done
                    make a rule,
                    1 change at a time,
                    AND save the working config.js before u edit
                      dwleo @sdetweil
                      Yeah, you are right. (sigh)
                      Anyway I ran it and got this:
                      pi@raspberrypi:~/MagicMirror $ node tests/configs/check_config.js
                        sdetweil @dwleo
                        @dwleo ok, then you have a module name wrong, or u deleted it
                        OR, you installed a module, but didn’t finish ITS install, by going to ITS folder and running npm install
                        when a module uses other modules, (some not used by base MM), you have to do a manual step to install ITS dependencies
                        so, I would look thru the modules u might have just installed, and edit the package.json file in each and look for moment-timezone… if its there, then u probably need to run npm install in that folder
                        D 2 Replies Last reply Reply Quote 1
                          dwleo @sdetweil
                          Thank you. I will try that.
                            dwleo @sdetweil
                            Hurray!
                            That did it. I must have used my ‘fat fingers’ when in the MMM-NHL file.
                            Thanks so much!
                              sdetweil @dwleo
                              @dwleo no problem… thanks for letting us know… the system is sensitive in certain spots!
                              can u mark your issue resolved?
