    Python in to the magic mirror.
    43 Posts 4 Posters 25.2k Views 4 Watching
      A Former User @paulvanderheijden90
      If possible, Instead image, post code itself.
      Anyway, You’d better to read docs more carefully.
      MMM-P2000.js
      /// MMM-P2000.js
      Module.register("MMM-P2000", {
        getDom: function() {
          var e = document.createElement("div")
          e.id = "DISPLAY"
          return e
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
              var timer = setInterval(()=>{
                this.sendSocketNotification("GIVE_ME_DATA")
              }, 1000)
              break
            case "HERE_IS_DATA":
              var e = document.getElementById("DISPLAY")
              e.innerHTML = payload
              break
      node_helper.js
      /// node_helper.js
      const spawn = require("child_process").spawn
      var NodeHelper = require("node_helper")
            case "GIVE_ME_DATA":
              this.job()
              break
        job: function() {
          var process = spawn("python", ["/home/pi/src/test.py"])
          process.stdout.on("data", (data)=>{
            console.log(data)
            this.sendSocketNotification("HERE_IS_DATA", data)
      I didn’t test. I wrote this code with only my brain. so there could be errors, but you can catch the concept.
      P 2 Replies Last reply
        paulvanderheijden90 @Guest
        @Sean Thank you very much im going to check the code and see if I can implement it in the magic mirror.
        Thank you I will let you know
          @sean
          Hello Sean, Again thank you very much for you’re valued help!.
          I spend yesterday after midday and evening with a friend figure out how you’re code is working. and we did some tests to send also somthing back to the Node helper and alote came clear by you’re example.
          So realy thank u very much.
          To day I spend my morning figure out one last problem the text on the screen is [ Object ArrayBuffer] and not the string I put true the stdout.write.
          The text that is displayed on the screen is : 0_1548411234909_Schermafbeelding 2019-01-25 om 11.09.42.png
          I did some debugging of my own. and wenn I override the data in the node helper just after it come from the spawn function this is displayed on the mirror. so the code is working until the spawn function.
          /// node_helper.js
                  this.job()
                  break
            job: function() {
          	data= "test hello World"
                console.log(data)
          So i tested also the python test project. and wenn I run it in the terminal it give no error. so the python project is fine aswell I think.
          import sys
          sys.stdout.write("Hallo Ik ben Paul")
          So I think the spawn function is not correct at this time?
          Can you help me out one more time please?
          ? 1 Reply Last reply
            @paulvanderheijden90 said in Python in to the magic mirror.:
            Object ArrayBuffer
            is one of javascript Object type. not text itself. (Sorry for my prior example. it needs to be converted from Object to HTMLText.)
            https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/ArrayBuffer
              console.log(data)
              // You can see the structure of this `data` object(ArrayBuffer) on the shell terminal.
              var result = String.fromCharCode.apply(null, new Uint16Array((data))
              // You need to convert or filter or manipulate `data` object whatever for your real usage.
              this.sendSocketNotification("HERE_IS_DATA", result)
            P 1 Reply Last reply
              @Sean Hello Sean,
              I was thinking somting was wrong because I see the buffer printing in the terminal showing:
              Buffer 48 61 6c 6c 6f 20 49 6b 20 62 65 6e 20 50 61 75 6c>
              i was trying to figure out the text line that it was representing but it was not showing something.
              So im happy you came up with the solution for the buffer.
              Unfortunly wenn at the var result code the magic mirror is crashing again and im not able to debug.
              Can you please heave a look at it
              /// node_helper.js
                      this.job()
                      break
                job: function() {
                    console.log(data)
                Crashing? show me the error log.
                  @sean said in Python in to the magic mirror.:
                  App threw an error during load
                  /home/pi/MagicMirror/modules/MMM-P2000/node_helper.js:76
                  }.call(this, exports, require, module, __filename, __dirname); });
                  SyntaxError: missing ) after argument list
                      at createScript (vm.js:80:10)
                      at Object.runInThisContext (vm.js:139:10)
                      at Module._compile (module.js:606:28)
                      at Object.Module._extensions..js (module.js:653:10)
                      at Module.load (module.js:561:32)
                      at tryModuleLoad (module.js:504:12)
                      at Function.Module._load (module.js:496:3)
                      at Module.require (module.js:586:17)
                      at require (internal/module.js:11:18)
                      at loadModule (/home/pi/MagicMirror/js/app.js:127:17)
                  Launching application.
                    Your log is telling you what is wrong.
                    See the 76 line of node_helper.js. There could be missing ) after argument list.
                      @sean So sorry you’re totally right… I was little bit confused by all the “at” conclusens.
                      Im sorry I could had fixed that. And I did !
                      Now it is working !!!
                      So very nice ! im going to put this in my P2000 Raspberry python Programma. and will heave a lot of play with it.
                      I will post/ show you the and result !
                        paulvanderheijden90
                        Hello @Sean,
                        Again thank you for the help. As I say after your help it was possible for me to “print” a string variable on the magic mirror module through python.
                        But is was not able to put my P2000 alarm from the fire department on my screen. I noticed that it was a problem in the python script of the alarm.
                        I used the stdout.write function again. like you told me. but I needed to add the flush function as wel.
                        so now it is
                        sys.stdout.write("hallo ik ben Paul")
                        sys.stdout.flush()
                        And then it was working !
                        so thank you and here the result:
                          @sean
                          Hello Sean,
                          like I posted yesterday the app is running now. And it is showing wat I need to display. So im very happy.
                          But…
                          After a time ( more after a couple of runs ) the magic mirror app is crashed and freezed. So noting is updating any more.
                          My feeling is telling that the buffer were I put in the string value is filling up.
                          wenn i run the python script without the mirror it is running fine.
                          Please can you give me a help?
                          ? S 2 Replies Last reply
                            I have no idea about Python. I think you’d better reboot once or twice per daily to maintain RPI to be stable. You can do it with cron automatically.
                            The better approach would be implementing your job as native nodeJS MagicMirror module instead external python script.
                              sdetweil @paulvanderheijden90
                              @paulvanderheijden90 can u put your project on github and tell me where it is… I will look at it later today (us time)
                                paulvanderheijden90 @sdetweil
                                Hallo Thank you for you’re Replay
                                I managed to upload the project on git hub ( new experience for me )
                                I uploaded the magic mirror Module ( P2000) I made and the node helper.
                                And I added the Python project.
                                The python project works fine on it self. But wenn I call ( spawn ) the python. The magic mirror application stops and freezes.
                                I think the flush/write fills the buffer and wenn it is it full the application is stoped.
                                https://github.com/paulvanderheijden90/MMM-P2000-python-connect
                                Here is the link
                                  sorry, the is no PUBLIC repo there
                                    @sean
                                    Hello Sean,
                                    The problem is not the python project. But I think the buffer is filling up ore something.
                                    At this point all the massages are displayed on the mirror and after 15 min the mirror is freeze.
                                    So im looking in to it.
                                      @sdetweil fixed sorry
                                        @paulvanderheijden90 i don’t see the python module
                                        you can add it to the directory and repo temporarily, then remove it later
                                          @paulvanderheijden90 so far I don’t see the same crash error…
                                          I did have to make some minor changes…
                                          Module name to match the git repo name
                                          path to a python script
                                          and change the display handling…
                                          rule is ONLY content change location is getDom()…
                                          other routines should store data and call updateDom(0 to signal that there ARE changes to display
                                          I’m gonna let it run for a while…
                                            hello ! Thank you for your help so far.
                                            The python project is running fine on it selfs.
                                            But wenn I use it with the magic mirror the buffer of the magic mirror is filling. And freezes.
                                            the python project is made in combination with a Antenna.
                                            Setup looks like https://nl.oneguyoneblog.com/2016/08/09/p2000-ontvangen-decoderen-raspberry-pi/#comment-488
                                            so you’ll need to have data from the Multimom to get different information to send to the mirror
                                            • 2 / 3
