MMM-SoccerLiveScore no pictures
4 Posts 3 Posters 1.3k Views 3 Watching
  • E Offline
    Ernst-Jan
    Goodmoring, Sometimes i have this error im my pm2 log mm.
    Can someone exxplane to my wat this main and what to do to fixed this.
    at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:36:30)
    0|mm | at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
    0|mm | at emitOne (events.js:116:13)
    0|mm | at Request.emit (events.js:211:7)
    0|mm | at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:877:8)
    0|mm | at ClientRequest.emit (events.js:211:7)
    0|mm | at TLSSocket.socketErrorListener (_http_client.js:387:9)
    0|mm | at TLSSocket.emit (events.js:211:7)
    E 1 Reply Last reply Jan 29, 2019, 2:16 PM Reply Quote 0
    • U Offline
      Ultimatum22 Module Developer
      @ernst-jan said in MMM-SoccerLiveScore no pictures:
      You left out the most important line. The first line says there is something wrong at line 36 character 30 in the file node_helper.js but probably is the error above this. So post a bit more or upload the log somewhere. But this looks more like a bug in the plugin itself and not the core system.
      • E Offline
        Ernst-Jan @Ernst-Jan
        Update line:
        0|mm | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:92:26)
        0|mm | code: ‘EAI_AGAIN’,
        0|mm | errno: ‘EAI_AGAIN’,
        0|mm | syscall: ‘getaddrinfo’,
        0|mm | hostname: ‘www.speedtest.net’,
        0|mm | host: ‘www.speedtest.net’,
        0|mm | port: 443 }
        0|mm | { Error: socket hang up
        0|mm | at createHangUpError (_http_client.js:331:15)
        0|mm | at TLSSocket.socketCloseListener (_http_client.js:363:23)
        0|mm | at emitOne (events.js:121:20)
        0|mm | at _handle.close (net.js:554:12)
        0|mm | at TCP.done [as _onclose] (_tls_wrap.js:356:7) code: ‘ECONNRESET’ }
        0|mm | [939:0129/080105.502591:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
        S 1 Reply Last reply Jan 29, 2019, 2:24 PM Reply Quote 0
          sdetweil @Ernst-Jan
          EAI_AGAIN
          google search on EAI_AGAIN returns
          EAI_AGAIN is a DNS lookup timed out error, means it is a network connectivity error
