    MMM-AssistantMk2
    421 Posts 61 Posters 744.7k Views 57 Watching
    • LicoriniL Offline
      Licorini
      Hello … I am a beginner, I am trying to install Mk2 following the instructions, however it presents errors as below:
      magicmirror@2.6.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.6.0
      Loading config …
      Loading module helpers …
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
      Expected directory: electron-v2.0-linux-arm-glibc
      Found: [node-v64-linux-arm-glibc]
      This problem can often be fixed by running “npm rebuild” on the current system
      Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node’
      App threw an error during load
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
      at Module._compile (module.js:642:30)
      at Object.Module._extensions…js (module.js:653:10)
      at Module.load (module.js:561:32)
      at tryModuleLoad (module.js:504:12)
      at Function.Module._load (module.js:496:3)
      at Module.require (module.js:586:17)
      at require (internal/module.js:11:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
      Whoops! There was an uncaught exception…
      { Error: Failed to load gRPC binary module because it was not installed for the current system
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
      Can someone help me ??
      • L Offline
        Lowis @Guest
        @sean but how can i setup the notification to start play MMM_Webradio ?
        MMM_Webradio has this notifications :
        WEBRADIO_ONOFF Starts / Pauses playback
        WEBRADIO_VOLUP Volume up by 5%
        WEBRADIO_VOLDOWN Volume down by 5%
        WEBRADIO_NEXT Next station
        WEBRADIO_PREV Previous station
          [[global:former-user]] @Licorini
          @licorini
          You’ve missed or failed electron-rebuild step. Do it with instruction on README
            [[global:former-user]] @Lowis
            @lowis
            There are two options to make custom commands - transcriptionHook and gAction.
            I’ll explain with transcriptionHook because it is easier (but limited)
            first. define hook phrase.
            transcriptionHook: {
              "RADIO": {
                pattern: "my radio",  // When you say "my radio",
                command: "RADIO_ONOFF" // command "RADIO_ONOFF" will be executed
              ... // if you need more hooks, add here.
            Then, Let’s make command RADIO_ONOFF to emit notification when your voice is hooked.
            command: {
              "RADIO_ONOFF": {
                notificationExec: {
                  notification: "WEBRADIO_ONOFF",
              ... // if you need more commands, add here.
            Now, when you say “my radio” in your voice order, “RADIO_ONOFF” command will be executed to send notification “WEBRADIO_ONOFF”.
            But, I think there could be a problem to use webradio. Because your radio sound will interrupt HOTWORD or AMK2 occasionally, it could make unintended misbehaviours. Anyway, I wish you good luck.
            • L Offline
              Lowis @Guest
              @sean thank you very much for the detailed information . Webradio is running !
              • T Offline
                teitlebot
                @Sean
                Thanks again for all the work and help
                So how would I get assistant module to disable and enable the google photo module?
                I would like to speak “Hide Photos” and the Google Photos will stop displaying.
                I know I need transition hook and command
                I tried learning how to do this using your example of hide clock except after I added the code nothing happened. When I say “hide clock” it searches google for hide clock instead of turning off module. So I must be doing something wrong
                BTW the hide all command works fine.
                  [[global:former-user]] @teitlebot
                  @teitlebot
                  I don’t know how you do your code. I have no second sight. Show your work to examine.
                  • E Offline
                    Egnos
                    Hi @Sean.
                    I have some questions to ask you:
                    • I installed AssistantMK2 and Hotword successfully but the only way to wake up the assistant is to say “snowboy”. The hot word “smartmirror” and “jarvis” do not work. Can you help me? (my config.js below…)
                    • When I ask for a song on youtube I can not stop the song anymore. The assistant does not listen to me. To talk to the assistant I have to wait for the end of the song. How do I solve?
                    • When the assistant begins to speak, he cuts the first words, is it possible to solve?
                    • The videos on youtube are reproduced in full screen. Is it possible to reproduce them in a small box (example: bottom right …)?
                    Thanks you for your great work and patience! :winking_face:
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    		  module: "MMM-AssistantMk2",
                    		    /*useWelcomeMessage: "brief today",*/
                    		    deviceLocation: {
                    					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                    					latitude: 45.200049, // -90.0 - +90.0
                    					longitude: 7.568917, // -180.0 - +180.0
                    			profiles: {
                    				"default" : { // profile name.
                    				profileFile: "default.json", // profile file name.
                    				lang: "it-IT",
                    				//currently available (estimation, not all tested):
                    				//  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
                    				// fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
                    				// https://developers.google.com/assistant/sdk/reference/rpc/languages
                    			record: { // Full values are in `FOR EXPERTS` section.
                    				recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
                    				device: "plughw:1"        // recording device (e.g.: "plughw:1")
                    			play: { // Full values are in `FOR EXPERTS` section.
                    				playProgram: "mpg321", // recommended.
                    			notifications: {
                            ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                            ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                        module: "MMM-Hotword",
                          record: {
                            recordProgram : "arecord",
                            device        : "plughw:1",
                          autostart:true,
                          onDetected: {
                            notification: function (payload) {
                              return "ASSISTANT_ACTIVATE"
                            payload: function (payload){
                              return {
                                profile: payload.hotword
                      module: 'MMM-Hotword',
                        snowboy: [
                        hotwords: "smartmirror", //this will be sent to other module for distinguishing which hotword is detected.
                        file: "resources/models/smart_mirror.umdl",
                        sensitivity: '0.5',
                        hotwords: "snowboy",
                        file: "resources/models/snowboy.umdl",
                        sensitivity: '0.5',
                        file: 'resources/models/jarvis.umdl',
                        sensitivity: '0.8,0.80',
                        hotwords: ['jarvis','jarvis'] //Kitt.ai changed their Jarvis UMDL, it has 2 models in one file. So weird.
                        //anyway, you can give different name for each. ['jarvis_1', 'jarvis_2']. Even though I think this is useless.
                        record: {
                          sampleRate    : 16000,      // audio sample rate
                          threshold     : 0.5,        // silence threshold (rec only)
                          thresholdStart: null,       // silence threshold to start recording, overrides threshold (rec only)
                          thresholdEnd  : null,       // silence threshold to end recording, overrides threshold (rec only)
                          silence       : 1.0,        // seconds of silence before ending
                          verbose       : true,      // log info to the console. Use this when you want to check mic working or not.
                          recordProgram : 'arecord',  // Defaults to 'arecord' - also supports 'rec' and 'sox'
                          device        : 'plughw:1'        // recording device (e.g.: 'plughw:1')
                        autostart: true,              // if 'false', this module will wait for 'HOTWORD_RESUME' notification to start hotwords detection at the beginning.
                        autorestart: false,          // You can set this 'true' when you want this module to go back to listening mode automatically again after hotword is detected. But use this carefully when your other modules are using microphone or speaker.
                        // customizable notification trigger
                        notifications: {
                          PAUSE: "HOTWORD_PAUSE",
                          RESUME: "HOTWORD_RESUME",
                          LISTENING : "HOTWORD_LISTENING",
                          SLEEPING : "HOTWORD_SLEEPING",
                          ERROR : "HOTWORD_ERROR",
                        onDetected: {
                          notification: (payload) => {
                            return "HOTWORD_DETECTED"
                          payload: (payload) => {
                            return payload
                            module: 'MMM-pages',
                                    modules:
                                        [[ "weatherforecast", "newsfeed"],
                                         [ "calendar", "compliments" ]],
                                    excludes: ["clock", "currentweather", "MMM-page-indicator", "MMM-AssistantMk2"],
                            module: 'MMM-page-indicator',
                            position: 'bottom_bar',
                                pages: 3,
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check-o ",
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "currentweather",
                    				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "La Stampa",
                    						url: "https://www.lastampa.it/rss.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true
                      [[global:former-user]] @Egnos
                      @egnos
                      Adjust sensitivity.
                      set pauseOnYoutube:false. You can activate hotword during videoplaying and it will stop the video. Anyway, there is a risk that your video sounds could also activate hotword.
                      I think you are using HDMI as output. HDMI could have that symptom. Use other output.
                      Redefine CSS selector #ASSISTANT_YOUTUBE in css/custom.css.
                      E R 2 Replies Last reply Reply Quote 0
                      • E Offline
                        Egnos @Guest
                        @sean said in MMM-AssistantMk2:
                        Adjust sensitivity.
                        The sensitivity of the microphone?
                        If yes, how do you do it?
                        Where should I make this modify?
                        Thanks a lot!
                          @egnos
                              sensitivity: '0.5', // < - SENSITIVITY
                          css/custom.css
                          • T Offline
                            teitlebot @jomwells
                            @jomwells @Sean
                            I seem to have always had this problem where after a reboot I sometimes need to manually change the hardware number of my usb mic. I saw @jomwells wrote a fix by changing the .asoundrc file but for some reason my system always changes the asoundrc back after any changes I make.
                            I wonder if you have any ideas of a fix for me?
                              @teitlebot
                              As far as I know, there be alias for device instead cardno. But not sure. I’m not familiar with these things.
                              • E Offline
                                Egnos
                                Sorry @Sean I’m new in the MagicMirror environment and I do not know all the components.
                                Where can I find information on what is needed and how to customize the “custom.css” file?
                                What do you mean:
                                MagicMirror use the “custom.css” or “main.css”?
                                B ? 2 Replies Last reply Reply Quote 0
                                  bhepler Module Developer @Egnos
                                  @egnos It uses both. Changes you make to custom.css will 1) be included in the mirror’s display and 2) persist if you update when new mirror code is released.
                                    @egnos
                                    There are 3 endpoints of CSS applied.
                                    • CSS of module itself(modules/SOMEMODULE/SOMEMODULE.css) : It is predefined CSS for module by it’s developer.
                                    • main magicmirror css (css/main.css) : This is common CSS for Mirror itself and basic default module CSS.
                                    • custom css (css/custom.css) : When you need to modify some CSS rules over SOMEMODULE.css and main.css, You can redefine or override that CSS rules here.
                                    By example;
                                    #ASSISTANT_YOUTUBE is defined in modules/MMM-AssistantMk2/MMM-AssistantMk2.js like this;
                                    #ASSISTANT_YOUTUBE {
                                      width:100%;
                                      height:100%;
                                      border:none;
                                      display:none;
                                      position:fixed;
                                      top:0;
                                      left:0;
                                      background-color:rgba(0,0,0,0.5);
                                      z-index:99999;
                                    When you want to modify some CSS rules - smaller size -, you can override those rules in your css/custom.css instead modify MMM-AssisntantMk2.js directly.
                                      width: 50%;
                                      height:50%;
                                      top: 25%;
                                      left: 25%;
                                      ADDED
                                      Step-by-step guide about custom gaction to make a timer feature on wiki page.
                                      https://github.com/eouia/MMM-AssistantMk2/wiki/Tip%3AMaking-Timer-with-gAction
                                        Davido
                                        @Sean : First of all, great Work from your side, my Assistant is working, but I have a question: Is it possible, that the answer box from google could stay a little bit longer onscreen? I also tried your custom.css customization, but it doesn’t work, changing it in MMM-AssistantMk2.css was successful, any suggestions?
                                        @Lowis : you wrote that your Radio is running, i was also successful, but are you also able to stop it with the voice command? My Mic reacts on saying the Hotword, but then nothing happens. Only a reboot stops the Radio
                                        ejay-ibmE L 2 Replies Last reply Reply Quote 0
                                        • ejay-ibmE Offline
                                          ejay-ibm Project Sponsor Module Developer @Davido
                                          @davido I think the option you are looking for regarding answer of assistant duration on screen is :
                                          “screenDuration”: 2000 // here for 2 seconds
                                          hope this helps
                                          Ejay
                                            bachoo786 @Guest
                                            @sean hello mate
                                            i want to install google assistant on my rpi 3b+. i have connected a bluetooth speaker and was wondering if it would work? i have tried in the past with my rpi2b but couldnt just install assistant.
                                            also is there a ste[ by step guide on how to install assistant?
                                            many thanks god bless.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 21
                                            • 22
                                            • 12 / 22
