Magic mirror booting for first time
Hello everyone,
Yesterday I began installing all that was necessary for my magic mirror with this tutorial. After some bugs, I finally managed to make this start but then… this happened (please ignore the wrong resolution, I still have to find a way to stabilize that since it sometimes changes when booting)
So my question is: can it possibly come from the way I installed this? Or is it really my config.js file?
Since you probably can’t tell without my config file, here it is:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, language: 'fr', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'Calendrier', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' config: { compliments:{ morning:[ 'blablabla!', 'blablabla!', 'blabalbal!' ] afternoon:[ 'blablabal', 'blabalbal!!' ] evening:[ 'blabalbal!!', 'blablabla?' ] } } }, { module: 'currentweather', position: 'top_right', config: { location: 'Paris', locationID: '2988507', //ID from http://www.openweathermap.org appid: '31a8ba8d6d5dc4953cc52ba06a675ecf' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'Paris', locationID: '2988507', //ID from http://www.openweathermap.org appid: '31a8ba8d6d5dc4953cc52ba06a675ecf' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "Libération", url: "rssliberationfr/rss/latest/", }, ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
This post is deleted! -
Please note that the guide you followed is ⚠︎EXTREMELY OUTDATED⚠︎. Please check this guide:
https://forum.magicmirror.builders/topic/236/complete-setup-tutorial -
So, should I re-install everything with the new guide?
If the missing coma doesn’t make it work I will anyway, thank you both!!
