    3 different Alexa modules, which one is the best?
    32 Posts 10 Posters 27.4k Views 12 Watching
    • johnnyboyJ Offline
      johnnyboy @romain
      romainR 1 Reply Last reply Reply Quote 0
      • romainR Offline
        romain @johnnyboy
        @johnnyboy Yes, But it’s not your fault. I have read an entire very long thread about mirror mirror on the wall (and maybe some others, I don’t remember if all the information were on the same spot or not) and it seem that one guy talked about trying that (changing the region) and the creator of the module himself didn’t knew Ireland was possible. But he did point out in which file the region thing was. (it wasn’t had to find though).
        So I do think he meant that “that one ‘must’ be in the us-east” because he didn’t knew there was another option.
        And he didn’t changed his tutorial to reflect that. (I’m guessing because he wasn’t able to test this way itself. Or maybe he wasn’t willing to)
          borrigan @romain
          @romain hi again!!
          I have done some progress. I followed your instructions, created the asound.conf file and setup myTest as the input device in the config.yaml file. When I run alexaPi, now it does not give me a microphone error, but a strange “Capture data too large” error. I get to hear the “hello” sound but when I speak “alexa” it won’t do anything.
          Really weird. Here is the full output of main.py execution:
          pi@raspberrypi:/opt/AlexaPi/src $ /opt/AlexaPi/src/main.py -d
          INFO: pocketsphinx.c(152): Parsed model-specific feature parameters from /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/feat.params
          Current configuration:
          [NAME]			[DEFLT]		[VALUE]
          -agc			none		none
          -agcthresh		2.0		2.000000e+00
          -allphone
          -allphone_ci		no		no
          -alpha			0.97		9.700000e-01
          -ascale			20.0		2.000000e+01
          -aw			1		1
          -backtrace		no		no
          -beam			1e-48		1.000000e-48
          -bestpath		yes		yes
          -bestpathlw		9.5		9.500000e+00
          -ceplen			13		13
          -cmn			live		batch
          -cmninit		40,3,-1		41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
          -compallsen		no		no
          -debug					0
          -dict					/usr/local/lib/python2.7/dist-packages/pocketsphinx/model/cmudict-en-us.dict
          -dictcase		no		no
          -dither			no		no
          -doublebw		no		no
          -ds			1		1
          -fdict
          -feat			1s_c_d_dd	1s_c_d_dd
          -featparams
          -fillprob		1e-8		1.000000e-08
          -frate			100		100
          -fsg
          -fsgusealtpron		yes		yes
          -fsgusefiller		yes		yes
          -fwdflat		yes		yes
          -fwdflatbeam		1e-64		1.000000e-64
          -fwdflatefwid		4		4
          -fwdflatlw		8.5		8.500000e+00
          -fwdflatsfwin		25		25
          -fwdflatwbeam		7e-29		7.000000e-29
          -fwdtree		yes		yes
          -hmm					/usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us
          -input_endian		little		little
          -jsgf
          -keyphrase				alexa
          -kws
          -kws_delay		10		10
          -kws_plp		1e-1		1.000000e-01
          -kws_threshold		1		1.000000e-10
          -latsize		5000		5000
          -lda
          -ldadim			0		0
          -lifter			0		22
          -lm
          -lmctl
          -lmname
          -logbase		1.0001		1.000100e+00
          -logfn
          -logspec		no		no
          -lowerf			133.33334	1.300000e+02
          -lpbeam			1e-40		1.000000e-40
          -lponlybeam		7e-29		7.000000e-29
          -lw			6.5		6.500000e+00
          -maxhmmpf		30000		30000
          -maxwpf			-1		-1
          -mdef
          -mean
          -mfclogdir
          -min_endfr		0		0
          -mixw
          -mixwfloor		0.0000001	1.000000e-07
          -mllr
          -mmap			yes		yes
          -ncep			13		13
          -nfft			512		512
          -nfilt			40		25
          -nwpen			1.0		1.000000e+00
          -pbeam			1e-48		1.000000e-48
          -pip			1.0		1.000000e+00
          -pl_beam		1e-10		1.000000e-10
          -pl_pbeam		1e-10		1.000000e-10
          -pl_pip			1.0		1.000000e+00
          -pl_weight		3.0		3.000000e+00
          -pl_window		5		5
          -rawlogdir
          -remove_dc		no		no
          -remove_noise		yes		yes
          -remove_silence		yes		yes
          -round_filters		yes		yes
          -samprate		16000		1.600000e+04
          -seed			-1		-1
          -sendump
          -senlogdir
          -senmgau
          -silprob		0.005		5.000000e-03
          -smoothspec		no		no
          -svspec					0-12/13-25/26-38
          -tmat
          -tmatfloor		0.0001		1.000000e-04
          -topn			4		4
          -topn_beam		0		0
          -toprule
          -transform		legacy		dct
          -unit_area		yes		yes
          -upperf			6855.4976	6.800000e+03
          -uw			1.0		1.000000e+00
          -vad_postspeech		50		50
          -vad_prespeech		20		20
          -vad_startspeech	10		10
          -vad_threshold		2.0		2.000000e+00
          -var
          -varfloor		0.0001		1.000000e-04
          -varnorm		no		no
          -verbose		no		no
          -warp_params
          -warp_type		inverse_linear	inverse_linear
          -wbeam			7e-29		7.000000e-29
          -wip			0.65		6.500000e-01
          -wlen			0.025625	2.562500e-02
          INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none'
          INFO: acmod.c(166): Using subvector specification 0-12/13-25/26-38
          INFO: mdef.c(518): Reading model definition: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/mdef
          INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
          INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/mdef
          INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
          INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/transition_matrices
          INFO: acmod.c(117): Attempting to use PTM computation module
          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/means
          INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
          INFO: ms_gauden.c(244):  128x13
          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/variances
          INFO: ms_gauden.c(304): 222 variance values floored
          INFO: ptm_mgau.c(476): Loading senones from dump file /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/sendump
          INFO: ptm_mgau.c(500): BEGIN FILE FORMAT DESCRIPTION
          INFO: ptm_mgau.c(563): Rows: 128, Columns: 5126
          INFO: ptm_mgau.c(595): Using memory-mapped I/O for senones
          INFO: ptm_mgau.c(838): Maximum top-N: 4
          INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
          INFO: dict.c(320): Allocating 138824 * 20 bytes (2711 KiB) for word entries
          INFO: dict.c(333): Reading main dictionary: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/cmudict-en-us.dict
          INFO: dict.c(213): Dictionary size 134723, allocated 1016 KiB for strings, 1679 KiB for phones
          INFO: dict.c(336): 134723 words read
          INFO: dict.c(358): Reading filler dictionary: /usr/local/lib/python2.7/dist-packages/pocketsphinx/model/en-us/noisedict
          INFO: dict.c(213): Dictionary size 134728, allocated 0 KiB for strings, 0 KiB for phones
          INFO: dict.c(361): 5 words read
          INFO: dict2pid.c(396): Building PID tables for dictionary
          INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
          INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
          INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
          INFO: kws_search.c(406): KWS(beam: -1080, plp: -23, default threshold -225, delay 10)
          2017-04-26 19:58:32 DEBUG: Setting up playback handler: SoxHandler
          2017-04-26 19:58:32 INFO: Checking Internet Connection ...
          2017-04-26 19:58:32 DEBUG: Starting new HTTPS connection (1): api.amazon.com
          2017-04-26 19:58:33 DEBUG: https://api.amazon.com:443 "GET /auth/o2/token HTTP/1.1" 404 29
          2017-04-26 19:58:33 INFO: Connection OK
          2017-04-26 19:58:33 INFO: AVS token: Requesting a new one
          2017-04-26 19:58:33 DEBUG: Starting new HTTPS connection (1): api.amazon.com
          2017-04-26 19:58:34 DEBUG: https://api.amazon.com:443 "POST /auth/o2/token HTTP/1.1" 200 980
          2017-04-26 19:58:34 INFO: AVS token: Obtained successfully
          2017-04-26 19:58:34 DEBUG: Stopping audio play
          2017-04-26 19:58:34 DEBUG: Stopped play. No SoX process to stop
          2017-04-26 19:58:34 DEBUG: Playing audio: /opt/AlexaPi/src/resources/hello.mp3
          Exception in thread Thread-1:
            File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
              self.run()
            File "/usr/lib/python2.7/threading.py", line 763, in run
              self.__target(*self.__args, **self.__kwargs)
            File "/opt/AlexaPi/src/alexapi/triggers/pocketsphinxtrigger.py", line 70, in thread
              _, buf = inp.read()
          ALSAAudioError: Capture data too large. Try decreasing period size
          2017-04-26 19:58:34 DEBUG: Started play. sox -q /opt/AlexaPi/src/resources/hello.mp3 -t alsa default vol -6 dB pad 0 0
          2017-04-26 19:58:36 DEBUG: Finished play.
          Thank you very much for your patience @romain
          Best regards,
          Gerardo
          • romainR Offline
            romain @borrigan
            @borrigan Try to let “default” as an input device rather than myTest. The default thing will be in charge to call myTest itself (I think putting myTest directly doesn’t work for some weird reason I don’t now about)
            Do you hear the “hello” when you run the script ?
            If you still have the error after using the default, then ty to change you input handler from sox to vlc.I don’t think that’s related but at this point trying stuff might be the right thing x) Maybe that will fix it.
              borrigan @romain
              @romain finally got it working by replacing myTest with default as you indicated. Than you so very much!! One short glitch though, sometimes Alexa’s phrases can not be heard completely. For example, at boot time I can hear “o” instead of “hello”. Same happens when talking to her.
              But it is working!! Now time to test MMM-AlexaPi
              Thanks again @romain
              • romainR Offline
                romain @borrigan
                @borrigan you’r welcom =)
                  borrigan @romain
                  @romain quick question, I’ve noticed that Alexa takes a few seconds to answer, sometimes around 20 seconds. Does this happen to you as well? Could it be a slow internet connection. Thanks again!
                  • romainR Offline
                    romain @borrigan
                    @borrigan It happen to me as well. MMM-alexa seem a little faster but it’s a pain to use so I rather wait few second for an answer
                    • UnboredU Offline
                      Unbored @romain
                      @romain said in 3 different Alexa modules, which one is the best?:
                      To do it, first deactivate the service with the terminal by writing sudo systemctl stop AlexaPi.service; sudo systemctl disable AlexaPi.service (you can reactivate later by doing sudo systemctl enable AlexaPi.service).
                      Then you can run AlexaPi yourself by writing in the terminal /opt/AlexaPi/src/main.py -d (If you you putted it on that location anyway).
                      Thanks. This proves that the Pi can hear me, process the input, have Alexa provide a spoken response, and peace of mind for me… Also, the response is comparable to my standalone Alexa, when running in this mode. Too bad, I can just run this method all the time.
                        Marnus @romain
                        @romain I have the exact same problem and can’t seem to find any brief explanation. Did you manage to sort out Alexa yourself ?
