    Can't seem to get PlayStation 3 Eye Camera to work
    13 Posts 4 Posters 8.2k Views 3 Watching
    • ChrisC
      Chris
      Modify your ~ / .asoundrc and /etc/asound.conf files
      sudo nano /etc/asound.conf
      sudo nano .asoundrc
      with this code:
      # ps3 eye + 3.5mm speaker Raspberry Pi
      ## Suggested by http://julius.sourceforge.jp/forum/viewtopic.php?f=9&t=66
      ## Modified by https://github.com/afzalive
      pcm.jack {
        type hw
        card ALSA
      pcm.array {
        type hw
        card CameraB409241
      pcm.softvol {
        type softvol
        slave.pcm "jack"
        control {
          name Master
          card 0
      pcm.cap {
        type plug
        slave.pcm "array"
        slave.channels 4
        ttable {
          0.0 30.0
          1.1 30.0
      pcm.!default {
          type asym
          playback.pcm "plug:softvol"
          capture.pcm {
            type plug
            slave.pcm "cap"
      ctl.!default {
        type hw
        card 0
      ctl.softvol {
        type hw
        card 0
      open a terminal and install pulseaudio:
      sudo apt-get install pulseaudio
      sudo apt-get install pavucontrol gstreamer0.10-pulseaudio
      reboot and in the menu of raspbian you should see a tab allowing you to access the pulseaudio settings (sound and video tabs).
      The PS3 mic will appear in it.
      I hope I have been clear in my indications,
      Regards,
      J 3 Replies Last reply
        jmartin1009 @Chris
        @chris oh wow, thank you! I’m not able to try this right now but I will give it a shot tonight, thank you so much!!
          jmartin1009 @Chris
          @chris I’m trying to do it right now but I can’t seem to find a file in etc/ named asound.conf, I can find asound.conf.swp and asound.conf.save, but it says I don’t have permission to rename, edit, or add a new file called asound.conf in the folder so idk what to do about that
            jmartin1009 @Chris
            @chris also when i tried to do the second line of the pulseaudio install, i got
            pi@raspberrypi:~ $ sudo apt-get install pauvcontrol gstreamer0.10-pulseaudio
            Reading package lists... Done
            Building dependency tree
            E: Unable to locate package pauvcontrol
            what do i do to fix this, thanks!
            ChrisC 1 Reply Last reply
            • yawnsY
              yawns Moderator
              It is pavucontrol, not pauvcontrol :-)
              J 1 Reply Last reply
                jmartin1009 @yawns
                @yawns what about the asound.conf file though? I can’t find it or create a new one to put that code in :/ but thanks for the help with the pavucontrol haha I didnt notice I read it wrong
                  sdetweil @jmartin1009
                  @jmartin1009 said in Can't seem to get PlayStation 3 Eye Camera to work:
                  asound.conf
                  that file is called .asoundrc
                  it is typically in the users home folder (/home/pi)… note that that the name starts with a dot (.)
                  • ChrisC
                    Chris @jmartin1009
                    it is actually pavucontrol and not pauvcontrol as yawms rightly pointed out.
                    the .asound.conf file is a hidden file. right-click in the file explorer window and choose to show hidden files. Normally it will appear.
                    In any case, if there is no sudo nano command .asound.conf in the terminal will create this file.
                    as sdetweil tells you, stick to the point at the beginning of the file.
                    Regards,
                      jmartin1009 @Chris
                      @chris @sdetweil @yawns I was able to edit the asoundrc file, but the .conf file wasn’t showing up as I was looking with the hidden files on, the only asound.conf files I could find were asound.conf.swp and asound.conf.save. I’m also kind of confused about how to save a new file in the terminal if I do the sudo nano method, because I was able to get into etc/ from there but it was only trying to have to overwrite a file, not create a new one, if there is a way to create a new file altogether for asound.conf, then I would like to know how to do that because it’s not appearing in hidden files and when I make the file in the terminal it seems like I can only overwrite. Thank you!
                        @jmartin1009 to make a new file, just rename the existing one to something else (asound.conf.save) and then create a new file
                          jmartin1009 @sdetweil
                          @sdetweil when I try to edit the name of the asound.conf.save file in order to create a new around.conf file, it tells me I don’t have permission to do it, or to delete it or really do anything with the file as well as that I don’t have permission to make a new file in the /etc/ folder. What do I do?
                            jmartin1009 @jmartin1009
                            @jmartin1009 nevermind I didn’t realize that entire time if I hit enter it would just make the file 🤦🏻‍♂️ I thought I had to go into files and everything, thank you!
