    MM and Kalliope: make Kalliope speaking
    14 Posts 4 Posters 4.9k Views 4 Watching
      sdetweil @NPX78
      @npx78 i do not know
        A Former User
        Consider MMM-GoogleTTS also.
          sdetweil @Guest
          @sean oops… didn’t see that one!
          • strawberry 3.141S Offline
            @NPX78 MMM-TTS is an offline text to speech, where you can choose a few different voices, but I assume the voice of the Google module sounds better, but is online.
            Here on the forum was once a member of the Kalliope team, you can reach out to him or on the kalliope project itself, if it needs to be that voice.
              A Former User
              @NPX78
              After reading your question again, I have a little confusing.
              As far as I know, Kalliope has its own TTS feature using pico2wave. And there be more options to use other TTS solution(including Google TTS). So I couldn’t understand why other MM TTS module is needed.
              • N Offline
                NPX78 @Guest
                @sean hello Sean.
                Using the TTS of Kalliope could be the better solution.
                But how can I call this fonctionnalité from a MM module
                Thank you for your time and explanations
                Regars
                Nicolas
                  A Former User @NPX78
                  @npx78
                  I have no experience with Kalliope so I’m not sure…
                  I think this is showing what you needs - https://kalliope-project.github.io/kalliope/rest_api/#run-a-synapse-from-an-order
                  So, by just calling Kalliope API with curl to run your reply synapse from your module after it’s job, couldn’t be done?
                  • N Offline
                    NPX78 @Guest
                    @sean Very good idea. Thank you.
                    I look for it this evening.
                    Currently : call the API REST with a synapse “repeat afer me …” : OK
                    I have some problem to call the curl into javascript module.
                    I use the XMLHttpRequest, but I have a beautiful: “400 (BAD REQUEST)” :)
                    After a night, my brain would be better :).
                    I will give you some news tomorrow.
                    • N Offline
                      NPX78
                      Hello everybody
                      Good night for my brain :) .
                      I solved my problem.
                      I will put the solution this evening (and will turn this post to solve)
                      Thanh you a lot to everybody in particular Sean.
                      Regards
                      Nicolas
                      • N Offline
                        NPX78
                        Spoiler Text
                        Hello
                        So my solution.
                        Kalliope Side :
                        //-- settings.yml file
                        # Rest API
                        rest_api:
                          active: True
                          port: 5000
                          password_protected: False
                          login: admin
                          password: secret
                          allowed_cors_origin: "*"
                        active:True allows using the Rest API
                        password_protected: False allows anonymous connections
                        allowed_cors_origin: allows connections from other sites. This option is mandatory because the MM site is localhost:8080 and kalliope 127.0.0.1:5000
                        Concerning the brain.yml file
                          - name: "repeat"
                            signals:
                              - order: "repeat after me {{sentence}}"
                            neurons:
                              - say:
                                  message: "{{sentence}}"
                        This synapse allows Kalliope repeat a sentence.
                        Magic Mirror side :
                        The following lines could be inserted in a module file
                        //-- Create the Request object.
                        const Http   = new XMLHttpRequest();
                        //-- Url to call fo our synapse.
                        const url    = 'http://localhost:5000/synapses/start/id/repeat';
                        //-- Build our data to send as parameters of our request.
                        var sent     = 'This is the text I want Kalliope repeat';    //-- You can modify it
                        var data     = {"parameters" : {'sentence':sent}};
                        var dataJson = JSON.stringify(data);
                        //-- Launch the request.
                        Http.open("POST",url);
                        Http.setRequestHeader("Content-type","application/json");
                        Http.send(dataJson);
                        I hope to be clear :)
                        I mark the post as Solved.
                        Thank you a lot for your time and ideas.
                        Regards
                        Nicolas
                          sdetweil @NPX78
                          @npx78 very cool… thank you for sharing and helping others…
