    MM and Kalliope: make Kalliope speaking
    14 Posts 4 Posters 5.2k Views 4 Watching
      A Former User
      Consider MMM-GoogleTTS also.
        sdetweil @Guest
        @sean oops… didn’t see that one!
        • strawberry 3.141S
          @NPX78 MMM-TTS is an offline text to speech, where you can choose a few different voices, but I assume the voice of the Google module sounds better, but is online.
          Here on the forum was once a member of the Kalliope team, you can reach out to him or on the kalliope project itself, if it needs to be that voice.
            A Former User
            @NPX78
            After reading your question again, I have a little confusing.
            As far as I know, Kalliope has its own TTS feature using pico2wave. And there be more options to use other TTS solution(including Google TTS). So I couldn’t understand why other MM TTS module is needed.
            N 1 Reply Last reply
            • N
              NPX78 @Guest
              @sean hello Sean.
              Using the TTS of Kalliope could be the better solution.
              But how can I call this fonctionnalité from a MM module
              Thank you for your time and explanations
              Regars
              Nicolas
              ? 1 Reply Last reply
                A Former User @NPX78
                @npx78
                I have no experience with Kalliope so I’m not sure…
                I think this is showing what you needs - https://kalliope-project.github.io/kalliope/rest_api/#run-a-synapse-from-an-order
                So, by just calling Kalliope API with curl to run your reply synapse from your module after it’s job, couldn’t be done?
                • N
                  NPX78 @Guest
                  @sean Very good idea. Thank you.
                  I look for it this evening.
                  Currently : call the API REST with a synapse “repeat afer me …” : OK
                  I have some problem to call the curl into javascript module.
                  I use the XMLHttpRequest, but I have a beautiful: “400 (BAD REQUEST)” :)
                  After a night, my brain would be better :).
                  I will give you some news tomorrow.
                  • N
                    NPX78
                    Hello everybody
                    Good night for my brain :) .
                    I solved my problem.
                    I will put the solution this evening (and will turn this post to solve)
                    Thanh you a lot to everybody in particular Sean.
                    Regards
                    Nicolas
                    • N
                      NPX78
                      Spoiler Text
                      Hello
                      So my solution.
                      Kalliope Side :
                      //-- settings.yml file
                      # Rest API
                      rest_api:
                        active: True
                        port: 5000
                        password_protected: False
                        login: admin
                        password: secret
                        allowed_cors_origin: "*"
                      active:True allows using the Rest API
                      password_protected: False allows anonymous connections
                      allowed_cors_origin: allows connections from other sites. This option is mandatory because the MM site is localhost:8080 and kalliope 127.0.0.1:5000
                      Concerning the brain.yml file
                        - name: "repeat"
                          signals:
                            - order: "repeat after me {{sentence}}"
                          neurons:
                            - say:
                                message: "{{sentence}}"
                      This synapse allows Kalliope repeat a sentence.
                      Magic Mirror side :
                      The following lines could be inserted in a module file
                      //-- Create the Request object.
                      const Http   = new XMLHttpRequest();
                      //-- Url to call fo our synapse.
                      const url    = 'http://localhost:5000/synapses/start/id/repeat';
                      //-- Build our data to send as parameters of our request.
                      var sent     = 'This is the text I want Kalliope repeat';    //-- You can modify it
                      var data     = {"parameters" : {'sentence':sent}};
                      var dataJson = JSON.stringify(data);
                      //-- Launch the request.
                      Http.open("POST",url);
                      Http.setRequestHeader("Content-type","application/json");
                      Http.send(dataJson);
                      I hope to be clear :)
                      I mark the post as Solved.
                      Thank you a lot for your time and ideas.
                      Regards
                      Nicolas
                        sdetweil @NPX78
                        @npx78 very cool… thank you for sharing and helping others…
