    2 Mirrors and one Sensor ( MMM-PIR-Sensor )
    11 Posts 3 Posters 4.4k Views 3 Watching
      binia
      is it posible to add only one sensor to 2 Raspberry Pi?
      Regards
        binia
        noone?
        I have in 1 Mirror 2 Display and Pi and want to add a sensor.
          sorry, do not understand question… typically one uses ONLY 1 PIR sensor…
            binia
            Sorry for my bad English.
            I have 2 Magic.Mirrors in a mirror and just wanted to use 1 PIR module for both.
            Therefore the question if this is technically possible or if I have to use a module for each raspberry.
              sdetweil @binia
              @binia oh!.. you have two monitors inside your single mirror!.. wow…
              all u need is the signal pin of the PIR… and connect the grounds together on the two PI devices…
              otherwise you could have one PI send a MMM message to the other to wakeup…
                binia
                0_1551861410991_IMG_20180916_150055.jpg 0_1551861416010_IMG_20180916_150101.jpg 0_1551861420245_IMG_20181218_144954.jpg 0_1551861424435_IMG_20181218_145005.jpg
                  binia
                  its 160cm x 65cm
                  One is a TV and one a Display
                    A Former User
                    You can install one PIR on one RPI(A).
                    Then, you can modify or build a module to send HTTPRequest to other RPI(B) on RPI(A) which has PIR sensor
                    Then, you can also modify or build a module to catch HTTPRequest on RPI(B) to use it as a signal for your job.
                    • MMM-PIR-Sensor (RPI(A)) : You can modify socektNotificationReceived() to emit your custom notification,
                      Or send HTTPRequest directly to RPI(B)
                    • MMM-NotificationTrigger (RPI(A)) : Or you can translate notification from MMM-PIR-Sensor to your custom notification for further relayed module,
                      Or you can execute directly external shell command/internal javascript for sending HTTPRequest when notification is coming from MMM-PIR-Sensor
                    • Or … you can build your own module for this job.
                    • MMM-Remote-Controller (RPI(B)) : You can get HTTPRequest from RPI(A) to do something
                    • MMM-NotificationTrigger(RPI(B)) : This module also can catch HTTPRequest and do something
                    • Or … you can build your module for this job.
                    • Or you can make scripts with javascript or python or any other language to communicate between two RPIs. It will be not so difficult to expert, but…
                      binia
                      Thanks for your answer.
                      I will try it.
                        A Former User
                        Here is a simple example for using MMM-NotificationTrigger. Not tested, but you can catch the concept.
                        Assumption
                        • RPI_A
                          • MM IP : 192.168.178.101:8080
                          • PIR_SENSOR is installed
                          • This will emit notification "USER_PRESENCE" with payload true/false
                        • RPI_B
                          • MM IP : 192.168.178.102:8080
                          • PIR_SENSOR IS not installed.
                          • It needs payload value of USER_PRESENCE from RPI_A
                        RPI_A MMM-NotificationTrigger config
                          module: "MMM-NotificationTrigger",
                            triggers: [
                                trigger: "USER_PRESENCE",
                                triggerPayloadFilter: (payload) => {
                                  return payload
                                fires: [
                                    fire: "DUMMY_NOTIFICATION",
                                    exec: `curl -d "notification=RELAYED_USER_PRESENCE&payload=true" http://192.168.178.102:8080/webhook`
                                  return !payload
                                fires: [
                                    exec: `curl -d "notification=RELAYED_USER_PRESENCE&payload=false" http://192.168.178.102:8080/webhook`
                        If USER_PRESENCE notification is emitted from MMM-PIR-Sensor, it will be translated to DUMMY_NOTIFICATION and curl shell command will be executed to transfer message(RELAYED_USER_PRESENCE) to RPI_B
                        RPI_B MMM-NotificationTrigger config
                            useWebhook: true,
                            triggers: [
                                trigger: "RELAYED_USER_PRESENCE",
                                fires: [
                                    fire: "DOING_MY_JOB",
                                    payload: (payload) => {
                                      return (payload == "true") ?  true : false
                        By useWebhook:true it can listen message from RPI_A. When RELAYED_USER_PRESENCE is coming, DOING_MY_JOB (or whatever you want) notification will be emitted on RPI_B
