    MMM-PIR-Sensor, Edit command for TVoff?
    3 Posts 3 Posters 1.1k Views 3 Watching
      costascontis
      Re: PIR-Sensor - put your mirror to sleep if not used
      can i use a custom command to turn my tv power save mode?My lg tv does not turn off with usual commands but i discovered that giving a
      /opt/vc/bin/tvservice -p
      the tv is shutting down the screen entering a power save mode or something…
      How can i use that command with the PIR module?
      S Cr4z33C 2 Replies Last reply Reply Quote 0
        sdetweil @costascontis
        @costascontis edit the node_helper and change the code
        • Cr4z33C Offline
          Cr4z33 @costascontis
          @costascontis give a look here.
          I use these commands everyday with my Samsung TV. :)
