    Weather & Newsfeed
    11 Posts 3 Posters 6.5k Views 3 Watching
      A Former User @jobjha1973
      @jobjha1973
      Put your local information in currentWeather part also.
      And, As far as I know, TV2 Nyheader rss feed url is “http://feeds.tv2.dk/nyhederne_seneste/rss”
        jobjha1973
        @Sean said in Weather & Newsfeed:
        Thanks Sean, now the news feed work but not the weather yet.
        can you see if i’m doing something wrong```
        module: “compliments”,
        position: “lower_third”
        module: “currentweather”,
        position: “top_right”,
        locationID: “”, //ID from https://openweathermap.org/city/6543928; unzip the gz file and find your city
        appid: “6543928”
        module: “weatherforecast”,
        header: “Weather Forecast”,
        appid: “6543928”
        module: “newsfeed”,
        position: “bottom_bar”,
        feeds: [
        title: “TV2 Nyheder”,
        url: “http://feeds.tv2.dk/nyhederne_seneste/rss”
        showSourceTitle: true,
        showPublishDate: true
          jobjha1973
          maybe i need to put the code in
          locationID: “6543928”, like this?
          hmm nope
            A Former User
            @jobjha1973
            I think 2614478 or 6543928 wil be locationId, not appId.
            AppId might be more long. It seems being missed in your configuration.
            J 1 Reply Last reply
              jobjha1973 @Guest
              @Sean
              okey thanks i’ll try and try again, and return if it don’t work
              ? 1 Reply Last reply
                @jobjha1973
                AppID(API key) Should look similar with this; 616969b353bc8c809aab84d4033c4f72
                  jobjha1973 @Guest
                  @Sean
                  i’ve tried to look for that code size but can only find the short one so it still wont work, i’ll try again tomorrow
                    sonicgoose @jobjha1973
                    @jobjha1973 You need to register with OpenWeather and they will provide you with an API key.
                    J 2 Replies Last reply
                      jobjha1973 @sonicgoose
                      @sonicgoose
                      thank you, i just did it now and put the API in the config but still no luck :-(
                        @sonicgoose
                        i’ve got it to work now, thanks to you all :-)
