    MMM-Spotify
    249 Posts 51 Posters 357.2k Views 54 Watching
      A Former User @kwaeksler
      @kwaeksler I think I can add device limitation to display or control. I’ll consider it on updates.
      • K
        kwaeksler @Guest
        @Sean That sounds great :-) Thank you!
        • ejay-ibmE
          ejay-ibm Project Sponsor Module Developer
          some more testing . With Spotify Familly. You can have 1 device set per email account .
          ejay
            A Former User
            updated
            1.1.0 (2019-03-25)
            • Added: touch(click) interface
            • Device Limitation : Now you can allow or limit devices to display its playing on MM.
            • Some CSS structure is changed.
            • Now this module can emit SPOTIFY_* notifications for other module.
            K 1 Reply Last reply Reply Quote 1
            • thymonT
              thymon
              Need the same for DEEZER :disappointed_face: :loudly_crying_face:
              • Cr4z33C
                Cr4z33 @thymon
                @thymon said in MMM-Spotify:
                Never got it working, but here it is.
                • Cr4z33C
                  Cr4z33
                  @Sean @ejay-ibm I’ve got a Spotify Premium account now so I was giving MMM-Spotify another shot, but I am stuck at instructions step #4.
                  I am logged in however I get INVALID_CLIENT: Invalid redirect URI in the webpage once I click the generated URL. :confused_face:
                  Any thoughts?
                    A Former User @Cr4z33
                    @Cr4z33
                    Your two values of “REDIRCT_URI” should be the same; Your spotify App setup and your spotify.config.json. Check again.
                    • Cr4z33C
                      Cr4z33 @Guest
                      @Sean sorry where shoud I look for that? :smiling_face_with_open_mouth_cold_sweat:
                      In the generated link or?
                      • Cr4z33C
                        Cr4z33
                        There’s more now I notice a following error message in the terminal
                        [SPOTIFY_AUTH] Error: null { error: 'invalid_request',
                          error_description: 'code must be supplied' }
                          @Cr4z33
                          Go to https://developer.spotify.com/dashboard/applications (login)
                          Then select your spotify app for this module. (You might have created one if you followed instruction)
                          Then check your redirect_uri with your spotify.config.json.
                          • Cr4z33C
                            Cr4z33 @Guest
                            @Sean that was the solution. :D
                            The redirect URI for some reason was empty.
                            As soon as I added it manually re-running step #4 worked like a charm. :thumbs_up_medium_skin_tone:
                            • Cr4z33C
                              Cr4z33
                              @Sean OK now a different issue.
                              I added the MMM-AssistantMk2 needed lines, but when I say ie. Michael Jackson on Spotify nothing happens…
                              Isn’t it supposed to play then straight on MagicMirror? :thinking_face:
                                @Cr4z33
                                If you didn’t make a proper command about it (with transciptionHook or gAction - I recommend gAction because spotify would be a reserved feature of real Google Assistant but not supported on this SDK level.), you can’t.
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @Sean well I followed your instructions so… :grimacing_face:
                                  gAction you say?
                                  Ouch that’s all new to me and I guess it will take a while then… OK… :confounded_face:
                                  • Cr4z33C
                                    Cr4z33
                                    @Sean OK maybe it is my fault, but it was my understanding that this Spotify module can be also a stand-alone player?
                                    For some reason a second try at Michael Jackson on Spotify made start the web player I was previously running on my computer…
                                    Does this mean that if I have Raspotify (how to set it up then?) I can actually run everything from the Pi?
                                      @Cr4z33
                                      This is not a standalone player. you need “RASPOTIFY” to play songs directly on MM.
                                      There is some API about standalone player, but unfortunately, RPI doesn’t support that feature.
                                      Your trial was not about this module on RPI. It was an original features of Google Assistant.
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @Sean I want them both. ;)
                                        Voice commands to play Spotify songs STRAIGHT in MM.
                                        Thanks for confirming I am going to have some Raspotify reading now.
                                        • ejay-ibmE
                                          @Cr4z33 if you don’t want to use gaction like me .
                                          I’ll share my transcription hook and command i’m using with this module and others.
                                          It works perfectly. with raspotify. raspotify is pretty easy to install and run.
                                          transcriptionHook: {
                                                  HIDE_ALL_MODULES: {
                                                      pattern: "standby mode",
                                                      command: "HIDEMODULES"
                                                    SHOW_ALL_MODULES: {
                                                      pattern: "show modules",
                                                      command: "SHOWMODULES"
                                                    SCREEN_ON: {
                                                      pattern: "turn on screen",
                                                      command: "SCREENON"
                                                    SCREEN_OFF: {
                                                      pattern: "turn off screen",
                                                      command: "SCREENOFF"
                                                    REBOOT: {
                                                      pattern: "reboot the mirror",
                                                      command: "REBOOT"
                                                    SHUTDOWN: {
                                                      pattern: "extinction totale",
                                                      command: "SHUTDOWN"
                                                    STOP_PLAY: {
                                                      pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                                                      command: "STOP_VID"
                                                   // STOP_PLAY2: {
                                                   //   pattern: "arrête la musique",
                                                   //   command: "STOP_VID"
                                          	 SPOTIFY_PREVIOUS: {
                                                  pattern: "previous song",
                                                  command: "SPOTIFY_PREVIOUS"
                                                  SPOTIFY_PAUSE: {
                                                  pattern : "stop the musique",
                                                  command: "SPOTIFY_PAUSE"
                                                  SPOTIFY_PLAY: {
                                                  pattern : "music please",
                                                  command: "SPOTIFY_PLAY"
                                                  SPOTIFY_NEXT: {
                                                  pattern: "next song",
                                                  command: "SPOTIFY_NEXT"
                                                  SPOTIFY_VOLUME: {
                                                  pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                                                  command: "SPOTIFY_VOLUME"
                                                  SPOTIFY_SEARCH: {
                                                  pattern: "play (.*) on Spotify",
                                                  command: "SPOTIFY_SEARCH"
                                          	SPOTIFY_SEARCH_PLAYLIST: {
                                                  pattern: "playlist (.*) on Spotify",
                                                  command: "SPOTIFY_SEARCH_PLAYLIST"
                                          	SPOTIFY_MA_PLAYLIST: {
                                          	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
                                          	command: "SPOTIFY_MA_PLAYLIST"
                                          	SPOTIFY_TRANSFER: {
                                          	pattern: "play the music on (.*)", // (.*)  is the name of your device
                                          	command: "SPOTIFY_TRANSFER"
                                                    VOLUME_UP: {
                                                      pattern: "volume up",
                                                      command: "CMD_VOLUME_UP"
                                                    VOLUME_DOWN: {
                                                      pattern: "volume down",
                                                      command: "CMD_VOLUME_DOWN"
                                                    SET_VOLUME: {
                                                      pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                                                      command: "CMD_VOLUME_SET"
                                                  command: {
                                                    STOP_VID: {
                                                      moduleExec: {
                                                        module: ["MMM-AssistantMk2"],
                                                        exec: (module, params, key) => {
                                                          module.assistant.subdom.youtube.innerHTML = "";
                                                          module.assistant.subdom.youtube.style.display = "none";
                                                          module.youtubePlaying = false;
                                          	   SPOTIFY_TRANSFER: {
                                          	    notificationExec: {
                                                        notification: "SPOTIFY_TRANSFER",
                                          	         payload: (params) => {
                                                           console.log("SPOTIFY_TRANSFER @",params)
                                                          return params[1];
                                                     SPOTIFY_PAUSE: {
                                                      notificationExec: {
                                                        notification: "SPOTIFY_PAUSE"
                                                  SPOTIFY_PLAY: {
                                                      notificationExec: {
                                                          notification: "SPOTIFY_PLAY"
                                          	    notificationExec:  {
                                          		notification: "SPOTIFY_PLAY",
                                          		console.log("SPOTIFY_MA_PLAYLIST")
                                          		return {
                                          			context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
                                          		notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
                                          		notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                                          	SPOTIFY_NEXT: {
                                                   notificationExec: {
                                                  SPOTIFY_PREVIOUS: {
                                                   notificationExec: {
                                                      notification: "SPOTIFY_PREVIOUS"
                                                  SPOTIFY_VOLUME: {
                                                   notificationExec: {
                                                     notification: "SPOTIFY_VOLUME",
                                                           console.log("SPOTIFY_VOLUME @",params)
                                                          return params[1];
                                          	SPOTIFY_SEARCH: {
                                                   notificationExec: {
                                                     notification: "SPOTIFY_SEARCH",
                                                          console.log("SPOTIFY_SEARCH @",params)
                                                          return {
        type: "artist,track,album,playlist",
        query: params[1],
        random:false,
                                                   notificationExec: {
                                                          console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                                                          return {
        type: "playlist",
        query: params[1],
        random:true,
                                                    CMD_VOLUME_UP: {
                                                      notificationExec: {
                                                        notification: "VOLUME_UP"
                                                    CMD_VOLUME_DOWN: {
                                                      notificationExec: {
                                                        notification: "VOLUME_DOWN"
                                                    CMD_VOLUME_SET: {
                                                      notificationExec: {
                                                        notification: "VOLUME_SET",
                                                        payload: (params, key) => {
                                                          console.log("@", params);
                                                          return params[1];
                                          hope this will help.
                                          @Sean let me know if you want me to update the wiki.
                                          Ejay
                                          ? Cr4z33C 2 Replies Last reply Reply Quote 1
                                            A Former User @ejay-ibm
                                            @ejay-ibm thanks. As your wish, my colleague.
                                            • 12
                                            • 13
                                            • 2 / 13
