    MMM-Assistantmk2 - SET default Question & Answers with voice response
    14 Posts 5 Posters 6.2k Views 5 Watching
    • I Offline
      icripps
      Yes, that’s what I have on my mirror , both AMK2 and Gassistpi. One problem I run into is, when the gassitpi is using the mic, you can’t use the same mic for AMK2 on the magic mirror. I am thinking the only solution to this problem is using two separate mics for the two separate voice assistance.
      • I Offline
        icripps
        I personally have gassitpi installed on my raspberry pi because of home automation; I wanna be able to control my relays and gpio’s locally without IFTTT
        • V Offline
          veejae
          Thanks, i will still wait for other suggestions… because I was also thinking if MMM-TTS (text to speech )
          can combine with transcription hook commands , … and execute text to speech
            [[global:former-user]]
            First, the natural way is using gAction to make response fulfillment.
            Or if you need TTS, there be also. Read docs.
              bolish
              Indeed, it seems gAction is the natural way to do it.
              If it’s just for playing like simple default question and simple default answer :
              “Who is the best” : “It’s you Sir”.
              Then, I’m doing it with IFTTT and it works perfect. Very simple…
              V 2 Replies Last reply Reply Quote 0
              • V Offline
                veejae @bolish
                @bolish wow… thanks very much for that input… I think thats what I am looking for , Can you give me more specific and detailed inputs how to integrate it ?
                  bolish
                  Just go to your IFTTT account, create a Google Assistant trigger / applet…
                  Did you at least searched or tried something with IFTTT befaore asking again?
                  Open the browser, go on Google, search for IFTTT, create an account, click on “create a trigger”, search for Google assistant…
                  And don’t forget to close your browser, turn the light off when you leave the room.
                  • V Offline
                    veejae @bolish
                    @bolish Yes tried before but I didnt know that I can set and execute a a question and answer with ifttt… , Do i need to install other module for that to set something on config,js?
                    • V Offline
                      veejae @bolish
                      trying to create ifttt , but there is no action for google assistant … how did you do your own?
                        bolish
                        ifttt already existing applet link
                        • Cr4z33C Offline
                          Cr4z33 @icripps
                          @icripps said in MMM-Assistantmk2 - SET default Question & Answers with voice response:
                          Then you would not need GassistPi in addition for that.
                          I can manage ALL of my existing home domotics with MMM-AssistantMk2 if I want.
                          Maybe the only mandatory thing is to have a Google Assistant device around as I have also two Google Home Mini?
