    Issue when I start the mirror
    5 Posts 3 Posters 1.6k Views 3 Watching
    • V Offline
      Vit73520
      I have that error and a black screen when i start the mirror. I have already tried npm rebuild but it doesn’t work. Anyone can help me ?
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      Check MagicMirror version for node helper 'MMM-GoogleBirthdaysProvider' - Minimum version:  2.6.0 - Current version: 2.7.1
      Version is ok!
      Module helper loaded: MMM-GoogleBirthdaysProvider
      Module helper loaded: MMM-NowPlayingOnSpotify
      Module helper loaded: MMM-AVStock
      Module helper loaded: mmm-hue-lights
      Module helper loaded: MMM-Formula1
      Module helper loaded: MMM-nasaastropic
      Module helper loaded: MMM-Remote-Control
      No helper found for module: MMM-Carousel.
      No helper found for module: MMM-chromecast.
      Module helper loaded: MMM-Screencast
      Module helper loaded: MMM-Instagram
      Module helper loaded: MMM-TweetsByTimelineOrList
      No helper found for module: MMM-Snow.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
      Expected directory: electron-v3.0-linux-arm-glibc
      Found: [electron-v2.0-linux-arm-glibc, node-v59-linux-arm-glibc]
      This problem can often be fixed by running "npm rebuild" on the current system
      Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node'
      Version is ok!
      App threw an error during load
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
      { Error: Failed to load gRPC binary module because it was not installed for the current system
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
      Launching application.
        sdetweil @Vit73520
        @Vit73520 there are instructions in the assistant install about how to get rid of this.
        I had to erase node_modules
        Change package.json electron version to 3.0.13 and npm install, and then use electron-rebuild to make it work
          sonicgoose @sdetweil
          @sdetweil @Vit73520 Do the same for MMM-Hotword if you’re using it, with the snowboy node module.
            sdetweil @sonicgoose
            @sonicgoose yes, both
            • V Offline
              Vit73520 @sdetweil
              @sdetweil @sonicgoose Ok thank you, I will do it
