    force_s3tc_enable overridden by environment.
    13 Posts 3 Posters 6.1k Views 3 Watching
      siddhartha
      i get warning but my MM doesn’t start i have tried so many solutions. but still no effect. do you have any idea where should i look for those HTML or chromium files ?
      • evroomE
        evroom
        Sorry, no idea.
        You could disable all modules (disabled: true,) and then enable them one by one (disabled: false,) until the issue appears.
        But also run cd ~/MagicMirror; npm run config:check to be sure you do not have a config issue.
        Perhaps the ATTENTION is not related to the config.
        MagicMirror version: 2.37.0
          siddhartha
          Thanks i will try that and if solves that i will post it here :)
          there is one more issue npm lodash.update vulnerability. i don’t think so that those are connected to each other.
            Are u using chrome as the browser?
            This error has been reported there frequently.
            Search force_s3tc_enable in google
              siddhartha
              Chromium. yeah i have seen many reports on google about this chrome/chromium :(
              I think must be issue with the GPU or else the syntax . i am looking into it but cant find anything :(
                siddhartha
                  sdetweil @siddhartha
                  @siddhartha so, what does 'does not start ’ mean?
                  npm start
                  in the Magic Mirror folder gets the command prompt back? or not
                  screen goes black, or not
                  have you done
                  export DISPLAY=:0
                  npm start
                  on my mm I also have to
                  npm --enable-transparent-visuals --disable-gpu start
                    siddhartha
                    After upgrading OS. i faced problem with display.
                    i fixed some problem with
                    npm audit fix --force.
                    Then i shifted to VNC
                    used DISPLAY=:1 and then the magicmirror started.
                    but now there ware two process running at time.
                    MagicMirror with DISPLAY=:0
                    MM with DISPLAY=:1
                    so using pm2 i deleted MagicMirror and gave reboot.
                    everything worked perfectly. so i changed back DISPLAY=:0 in MM.
                    and gave reboot again…
                    and problem solved. no black screen no error :)
                      Cool. Thx for the feedback
                        siddhartha
                        No problem. Thank you :)
                          @siddhartha could u mark your issues solved… thx
