    force_s3tc_enable overridden by environment.
    13 Posts 3 Posters 5.7k Views 3 Watching
      siddhartha
      • evroomE Offline
        evroom
        I get the warning too, but MM does start.
        There are several hits using google.
        Seems to be a Chromium and HTML syntax issue.
        MagicMirror version: 2.36.0
          siddhartha
          i get warning but my MM doesn’t start i have tried so many solutions. but still no effect. do you have any idea where should i look for those HTML or chromium files ?
          • evroomE Offline
            evroom
            Sorry, no idea.
            You could disable all modules (disabled: true,) and then enable them one by one (disabled: false,) until the issue appears.
            But also run cd ~/MagicMirror; npm run config:check to be sure you do not have a config issue.
            Perhaps the ATTENTION is not related to the config.
              siddhartha
              Thanks i will try that and if solves that i will post it here :)
              there is one more issue npm lodash.update vulnerability. i don’t think so that those are connected to each other.
                Are u using chrome as the browser?
                This error has been reported there frequently.
                Search force_s3tc_enable in google
                  siddhartha
                  Chromium. yeah i have seen many reports on google about this chrome/chromium :(
                  I think must be issue with the GPU or else the syntax . i am looking into it but cant find anything :(
                    siddhartha
                      sdetweil @siddhartha
                      @siddhartha so, what does 'does not start ’ mean?
                      npm start
                      in the Magic Mirror folder gets the command prompt back? or not
                      screen goes black, or not
                      have you done
                      export DISPLAY=:0
                      npm start
                      on my mm I also have to
                      npm --enable-transparent-visuals --disable-gpu start
                        siddhartha
                        After upgrading OS. i faced problem with display.
                        i fixed some problem with
                        npm audit fix --force.
                        Then i shifted to VNC
                        used DISPLAY=:1 and then the magicmirror started.
                        but now there ware two process running at time.
                        MagicMirror with DISPLAY=:0
                        MM with DISPLAY=:1
                        so using pm2 i deleted MagicMirror and gave reboot.
                        everything worked perfectly. so i changed back DISPLAY=:0 in MM.
                        and gave reboot again…
                        and problem solved. no black screen no error :)
                          Cool. Thx for the feedback
                            siddhartha
                            No problem. Thank you :)
                              @siddhartha could u mark your issues solved… thx
