    MMM-PIR-Sensor not working with latest release - display does not turn off
    11 Posts 4 Posters 7.0k Views 4 Watching
    • K Offline
      Kugelfang
      Dear all,
      I’ve been using MM for over 1,5 years now. Unfortunately my SD card died yesterday so I took the opportunity to start from scratch.
      I installed the latest release 2.7.1 on my RBPi 3. using the “Full KMS” OpenGl driver. Unfortunately my PIR Sensor does not work anymore as my display stays on all the time. Interestingly I’m able to turn the display on an off manually via SSH using
      vcgencmd display_power 0
      vcgencmd display_power 1
      I already checked the wiring (which I actually did not change from my setup which was working for a long time) and I also checked the signal line of the PIR Sensor. Both are ok.
      My configuration looks like this:
      			module: 'MMM-PIR-Sensor',
      				sensorPIN: 23,
      				powerSavingDelay: 15
      It would be great if someone could help me out as I’m clearly missing something…
      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
      • thedoorsfanaticT Offline
        thedoorsfanatic @Kugelfang
        @Kugelfang
        Hi, I updated to 2.7.1 yesterday and also installed MMM-PIR-Sensor which works fine for me (https://youtu.be/5Cs3pCZamuM)
        I am not using the Full KMS driver though
        Did you follow these steps also:
        Execute npm install to install the node dependencies.
        Add your user (pi?) to the gpio group by executing sudo usermod -a -G gpio pi.
        Execute sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt to allow turning on/off the hdmi output.
        Reboot your Pi.
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        • K Offline
          Kugelfang
          Yes, I did. to my best knowledge the tcservice does not work with the KMS driver.
          Also looking into the details at GitHub I thought that MMM-PIR-Sensor actually uses the vcgencmd
            @Kugelfang
            I am really no expert at all but here is another tipp of mine:
            I also use these modules to turn off my monitor:
            MMM-ModuleScheduler + MMM-Remote-Control (at a certain time)
            and MMM-NetworkScanner (when my phone is not connected to my WLAN)
            • K Offline
              Kugelfang
              actually I checked the pm2 logs and found loots of this messages:
              npm ERR!     /home/pi/.npm/_logs/2019-04-03T22_01_36_315Z-debug.log
              /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.7.1 start script.
              does anybody know how to fix this?
                sdetweil @Kugelfang
                @Kugelfang yes, you will need to install electron-rebuild in that module
                from the MMM-PIR folder
                npm install electron-rebuild
                then run it to force the epoll rebuild
                node_modules/.bin/electron-rebuild
                • K Offline
                  Kugelfang
                  @sdetweil said in MMM-PIR-Sensor not working with latest release - display does not turn off:
                  Holy SHIT that worked. I’m now using the MMM-PIR instead of the MMM-PIR-Sensor
                  thanks you so much!!!
                  EDIT:
                  for the record: there are two PIR modules avaliable: Initially I intended to go with MMM-PIR-Sensors as I’ve been using this in the past. Unfortunately I couldn’t get it to work with the newly installed setup. Hence I choose MMM-PIR.
                  Besides the suggestion from @sdetweil I also modified the displayOff.sh and displayON.sh from
                  tvservice -o
                  to
                  so the module works with the full KMS OpenGL driver.
                    shgmongohh @Kugelfang
                    @Kugelfang
                    Where did you change the displaOff.sh? Where can I find this?
                    Sebastain
                      sdetweil @shgmongohh
                      @shgmongohh in the module folder
                        shgmongohh @sdetweil
                        In which folder ?
                          @shgmongohh too many pir modules
                          https://github.com/cowboysdude/Pir-Sensor has one
                          https://github.com/mboskamp/MMM-PIR has one, in callbackscripts folder
