    Help with Update to 2.7.0
    13 Posts 5 Posters 6.5k Views 5 Watching
    • K Offline
      Kenny
      git remote -v
      RESPONSE:
      origin https://github.com/MichMich/MagicMirror.git (fetch)
      origin https://github.com/MichMich/MagicMirror.git (push)
      • CyruS1337C Offline
        CyruS1337 Project Sponsor
        Run the following command in the MagicMirror folder
        rm package-lock.json
        rm vendor/package-lock.json
        Then execute in the folder the usual command for the upload
        git pull && npm install
        Now it should work
        Atelier-Made-in-iKiA 1 Reply Last reply Reply Quote 2
        • K Offline
          Kenny
          Thanks for the help @sdetweil and @CyruS1337. The latest suggestion gave me the same "Updating … " response.
          I just renamed my MagicMirror folder and did a clean install. Everything is working great again. THANKS!
          • Atelier-Made-in-iKiA Offline
            Atelier-Made-in-iKi @CyruS1337
            @CyruS1337 said in Help with Update to 2.7.0:
            Now it should work
            @CyruS1337 this solved the firt install command but…
            ownloading tmp-2822-0-electron-v3.0.13-linux-armv7l.zip
            Error: read ECONNRESET
            /home/pi/MagicMirror/node_modules/electron/install.js:49
              throw err
                at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
            npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! electron@3.0.13 postinstall: `node install.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron@3.0.13 postinstall script.
            npm ERR!     /home/pi/.npm/_logs/2019-04-05T19_09_38_688Z-debug.log
            pi@raspberrypi:~/MagicMirror $
            > magicmirror@2.7.1 start /home/pi/MagicMirror
            > sh run-start.sh
            run-start.sh: 4: run-start.sh: electron: not found
            npm ERR! file sh
            npm ERR! errno ENOENT
            npm ERR! syscall spawn
            npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! Failed at the magicmirror@2.7.1 start script.
            if an idea
            thanks
            Jean-Philippe
            • swvalentiS Offline
              swvalenti Project Sponsor
              pi@raspberrypi:~ $ cd MagicMirror
              pi@raspberrypi:~/MagicMirror $ git remote -v
              pi@raspberrypi:~/MagicMirror $ rm package-lock.json
              pi@raspberrypi:~/MagicMirror $ rm vendor/package-lock.json
              pi@raspberrypi:~/MagicMirror $ git pull && npm install
              Updating de57daa..b508a62
              Still have the same issue and can’t update…any help would be appreciated.
                @swvalenti said in Help with Update to 2.7.0:
                ok, lets try this
                git stash
                git pull
                if ok, then npm install
                  pi@raspberrypi:~/MagicMirror $ git stash
                  fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
                  Another git process seems to be running in this repository, e.g.
                  an editor opened by 'git commit'. Please make sure all processes
                  are terminated then try again. If it still fails, a git process
                  may have crashed in this repository earlier:
                  remove the file manually to continue.
                  Cannot save the current index state
                  pi@raspberrypi:~/MagicMirror $ npm install
                  > magicmirror@2.6.0 install /home/pi/MagicMirror
                  > cd vendor && npm install
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  audited 220 packages in 11.323s
                  found 4 low severity vulnerabilities
                    run `npm audit fix` to fix them, or `npm audit` for details
                  > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
                  > sh installers/postinstall/postinstall.sh && npm run install-fonts
                  MagicMirror installation successful!
                  > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                  > cd fonts && npm install
                  audited 1 package in 2.065s
                  found 0 vulnerabilities
                  audited 2427 packages in 54.343s
                  found 12 vulnerabilities (6 low, 6 moderate)
                  still not working…
                    ok, erase that file, or rename it out of the way
                    then
                    git pull
                      Thanks @sdetweil had to remove all the .json/locks and the .git after I had to enable show hidden files as I couldn’t find same. You da man Sam.
