    modules.data.position is not changed
    4 Posts 2 Posters 1.1k Views 2 Watching
    • E Offline
      emrhssla
      I use MMM-Modulbar.
      In the middle of the original code
      If(num=1){
      console.log (“Button number”+num);
      console.log (“dddddddddddd”+modules [idatadata.position);
      modules [idatadata.position=“top_left”;
      I put in but failed.
      num is the number of the button and modules[i] is about which module is pressed.
      All the consoles were reported to have changed to normal, but the module did not actually change its position.
      The original code is as follows, and the modified part of the code is from the 98th line.
      Module.register(“MMM-Modulebar”,{
      requiresVersion: "2.1.0",
      defaults: {
          // Allow the module to force modules to be shown (if hidden and locked by another module ex. profile-switcher).
          allowForce: false,
          // Determines if the border around the buttons should be shown.
          showBorder: true,
          // The minimum width for all the buttons.
          minWidth: "0px",
          // The minimum height for all the buttons.
          minHeight: "0px",
          // The location of the symbol relative to the text. Options: left, right, top or bottom
          picturePlacement: "left",
          // The direction of the bar. Options: row, column, row-reverse or column-reverse
          direction: "row",
      	// The speed of the hide and show animation.
      	animationSpeed: 1000,
          // The default button 1. Add your buttons in the config.
      	buttons: {
              "1": {
      			// The modules exact name to be affected.
      			module: "clock",
      			// The text to be displayed in the button.
      			text:	"Clock",
      			// Then symbol from font-awesome!
                  symbol: "clock-o"
      // Define required styles.
      getStyles: function(){
      	return ["font-awesome.css", "MMM-Modulebar.css"];
      // Override dom generator.
      getDom: function() {
          var menu = document.createElement("span");
          menu.className = "modulebar-menu";
          menu.id = this.identifier + "_menu";
          menu.style.flexDirection = this.config.direction;
      	// Sends each button to the "createButton" function be created.
      	for (var num in this.config.buttons) {
      		menu.appendChild(this.createButton(this, num, this.config.buttons[num], this.config.picturePlacement));
          return menu;
      // Creates the buttons.
      createButton: function (self, num, data, placement) {
      	// Creates the span elemet to contain all the buttons.
      	var item = document.createElement("span");
          // Builds a uniqe indentity / button.
      	item.id = self.identifier + "_button_" + num;
          // Sets a class to all buttons.
      	item.className = "modulebar-button";
          // Makes sure the width and height is at least the defined minimum.
      	item.style.minWidth = self.config.minWidth;
          item.style.minHeight = self.config.minHeight;
      	// Collects all modules loaded in MagicMirror.
      	var modules = MM.getModules();
      	// When a button is clicked, the module either gets hidden or shown depending on current module status.
      	item.addEventListener("click", function () {
      		// Lists through all modules for testing.
      		for (var i = 0; i < modules.length; i++) {
      			// Check if the curent module is the one.
      			if (modules[i].name === data.module) {
      				// Splits out the module number of the module with the same name.
      				var idnr = modules[i].data.identifier.split("_");
      				// Checks if idnum is set in config.js. If it is, it only hides that module, if not hides all modules with the same name.
      				if (idnr[1] == data.idnum || data.idnum == null) {
      					// Check if the module is hidden.
      					if (modules[i].hidden) {
      						// Check if there is a "showURL" defined.
      						if (data.showUrl != null) {
      							// Visiting the show URL.
      							fetch(data.showUrl);
      							// Prints the visited hideURL.
      							console.log("Visiting show URL: "+data.showUrl);
      						if(num==1){
      							console.log("button number"+num);
      							//modules[i].config.searchlist1="";
      							console.log("ddddddddd"+modules[i].data.position);
      							modules[i].data.position="top_left";
      							console.log("ddddddddd"+modules[i].config.searchlist1);
      						modules[i].show(self.config.animationSpeed, {force: self.config.allowForce});
      						// Prints in the console what just happend (adding the ID).
      						console.log("Showing "+modules[i].name+" ID: "+idnr[1]);
      					}else{
      						// Hides the module.
      						modules[i].hide(self.config.animationSpeed, {force: self.config.allowForce});
      						console.log("Hiding "+modules[i].name+" ID: "+idnr[1]);
      						// Check if there is a "hideURL" defined.
      						if (data.hideUrl != null) {
      							// Visiting the the URL.
      							fetch(data.hideUrl);
      							console.log("Visiting hide URL: "+data.hideUrl);
      	// Fixes the aligning.
          item.style.flexDirection = {
              "right"  : "row-reverse",
              "left"   : "row",
              "top"    : "column",
              "bottom" : "column-reverse"
          }[placement];
      	// Sets the border around the symbol/picture/text to black.
          if (!self.config.showBorder) {
              item.style.borderColor = "black";
      	// Adds the Font-Awesome symbol if specified.
          if (data.symbol) {
              var symbol = document.createElement("span");
              symbol.className = "modulebar-picture fa fa-" + data.symbol;
      		// Sets the size on the symbol if specified.
              if (data.size) {
                  symbol.className += " fa-" + data.size;
                  symbol.className += data.size == 1 ? "g" : "x";
      		// Align the symbol with a margin.
              if (data.text && placement === "left") {
                  symbol.style.marginRight = "4px";
      		// Adds the symbol to the item.
              item.appendChild(symbol);
      	// Adds a picture if specified.
      	} else if (data.img) {
              var image = document.createElement("img");
              image.className = "modulebar-picture";
              image.src = data.img;
      		// Sets the size of the picture if specified.
              if (data.width)  image.width  = data.width;
              if (data.height) image.height = data.height;
      		// Align the picture with a margin.
                  image.style.marginRight = "4px";
      		// Adds the picture to the item.
              item.appendChild(image);
      	// Adds the text if specified.
          if (data.text) {
              var text = document.createElement("span");
              text.className = "modulebar-text";
              text.innerHTML = data.text;
      		// Align the text with a margin.
              if ((data.symbol || data.img) && placement === "right") {
                  text.style.marginRight = "4px";
      		// Adds the text to the item.
              item.appendChild(text);
      	// All done. :)
          return item;
      notificationReceived: function(notification, payload) {
      	if(notification === "DOM_OBJECTS_CREATED"){
      		this.hide()
        the module is positioned when it is created, and never after…
        by position, it is appended to the div in the MM base div tree under the position defined.
        so, to make it move, you would have to remove it from the DOM in its old position and add it to the DOM in its new position (append, insert,… whatever)
        this is done in MagicMirror/js/main.js
        			var wrapper = selectWrapper(module.data.position);    // < ----- find div container based on position
        			var dom = document.createElement("div");
        			dom.id = module.identifier;
        			dom.className = module.name;
        			if (typeof module.data.classes === "string") {
        				dom.className = "module " + dom.className + " " + module.data.classes;
        			dom.opacity = 0;
        			wrapper.appendChild(dom);   // < ---  add this module to that container div
        • E Offline
          emrhssla @sdetweil
          @sdetweil thank you i like you very very thank you
            sdetweil @emrhssla
            @emrhssla if you did this kind of change, the module code should not know…
