    I don't know how to use node_helper.js.
    6 Posts 2 Posters 2.8k Views 2 Watching
    • E Offline
      emrhssla
      I tried to use python-shell. So I successfully finished the npm install python-shell.
      But I saw it said that to use python-shell, you must use node_helper.js.
      So I tried to execute a simple Python code. The notification I_DID in node_helper.js was well communicated and executed. However, the console in node_helper.js is not output, nor is python-shell working.
      What is the problem?
      var Testpythons;
      Module.register("MMM-Testpython", {
          defaults: {},
          start: function (){
              Testpythons = this;
        getDom: function() {
          var element = document.createElement("div")
          element.className = "myContent"
          element.id="divid"
          element.innerHTML = "Hello, World!!! " + this.config.foo
          var subElement = document.createElement("p")
          subElement.innerHTML = "Click"
          subElement.id = "clickid"
          element.appendChild(subElement)
          return element
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
            var elem = document.getElementById("clickid")
            elem.addEventListener("click", () => {
              Testpythons.sendSocketNotification("TESTPYTHON")
              console.log("hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~")
              elem.innerHTML = "click success"
              break
            case "I_DID":
              console.log("success")
              var elemk = document.getElementById("divid")
              elemk.innerHTML = "I_DID"
              break
      node_helper.js
      var NodeHelper = require("node_helper");
      var PythonShell = require('python-shell');
        start: function() {
          console.log("Starting module: " + this.name);
            case "TESTPYTHON":
              console.log("notification : " + notification)
              this.sendSocketNotification("I_DID")
              PythonShell.runString('print("Hello Python")', null, function (err, result) {
                  if (err) throw err;
                  console.log(result);
              break
        see https://ourcodeworld.com/articles/read/286/how-to-execute-a-python-script-and-retrieve-output-data-and-errors-in-node-js
        but your should have been ok… do you see the message
        in the terminal window?
        • E Offline
          emrhssla @sdetweil
          • E Offline
            emrhssla @emrhssla
            var {PythonShell} = require('python-shell');
              start: function() {
                  case "TESTPYTHON":
                        if (err) throw err;
                    break
            console doesnt show Starting module…
              sdetweil @emrhssla
              @emrhssla ok, there are two different output areas…
              the developers window, which u posted is from the module.js side…
              the node helper content comes out in the terminal window.
              start you mirror app,
              then start it with
              npm start &
              (note the & at the end)
              now you should be able to see any messages in the terminal window from the node_helper
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                emrhssla @sdetweil
                @sdetweil oh!!! 0_1555075761914_acdbfe01-9c20-45b9-a177-87d554b225e0-image.png
                thank you very very very much :)
