    Even a simple node_help.js example does not run.
    13 Posts 2 Posters 4.2k Views 2 Watching
      @emrhssla said in Even a simple node_help.js example does not run.:
      Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
      as I posted in the other topic, the node_helper content would be displayed in the terminal window
      where u started MM…
      also
      Log.log will not work in node helper. that is only available in the module.js
        also, you need to install the python-shell component…
        need a package.json file
          "name": "MMM-Testpython",
          "description": "sample",
          "version": "0.0.1",
          "dependencies": {
            "python-shell": "latest"
        and then run
        npm install
        in the module folder
        the updated node_helper.js is
        var NodeHelper = require("node_helper");
        var {PythonShell} = require('python-shell');
          start: function() {},
            console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
        and produces this message in the terminal window, when the UI component is clicked
        MMM-Testpython received a socket notification: TEST - Payload: [object Object]
        E 2 Replies Last reply Reply Quote 0
        • E
          emrhssla @sdetweil
          Is it normal for these errors to occur?
          /modules/MMM-Testpython/package.json
          • E
            emrhssla @sdetweil
            @sdetweil said in Even a simple node_help.js example does not run.:
            //var {PythonShell} = require('python-shell');
            omg…
              sdetweil @emrhssla
              @emrhssla sorry, I had a name of “sample” when I did it. I guess the - is not allowed
                sdetweil @emrhssla
                @emrhssla that log is only from the module file. Not node_helper
                • E
                  emrhssla @sdetweil
                    "name": "MMMTestpython",
                    "description": "samples",
                    "version": "0.0.1",
                    "dependencies": {
                  Do I have to change it like this and install it again? npm install
                    sdetweil @emrhssla
                    @emrhssla I don’t understand… mine worked perfectly
                    package.json
                      "keywords": [
                        "   none"
                      "version": "0.0.1",
                      "dependencies": {
                    /MagicMirror/modules/MMM-Testpython$ npm install
                    npm WARN MMM-Testpython@0.0.1 No repository field.
                    npm WARN MMM-Testpython@0.0.1 No license field.
                    added 1 package from 1 contributor and audited 1 package in 0.821s
                    found 0 vulnerabilities
                    odroid@odroid:~/MagicMirror/modules/MMM-Testpython$
                    what version of npm do you have
                    npm -v
                    • E
                      emrhssla @sdetweil
                        sdetweil @emrhssla
                        @emrhssla no…
                        mine is uppercase… oh well… anyhow u got it…
                        same npm version
                        • E
                          emrhssla @sdetweil
                          omg…
                            Looks like your system doesn’t have python installed.
