    Setup from scratch for beginners?
    7 Posts 2 Posters 1.4k Views 2 Watching
      first, lets see if there is an error
      on the black screen, using keyboard press crtl-shift-i to open the developers window
      then using mouse select the console tab, and scroll up to see if there are any errors…(red text)
      black screen is usually caused by some fatal error in the UI components
        Adrian_O
        Thank you Sam
        These are the errors
        Seems, the access on those links not possible.
        When I manually click on those links, I see them.
        (Do I have a problem with port 8080 being blocked and used by other applications)
        I may ask stupid questions. Please be patient with a beginner like me…
        But I see a lot of users having similar problems after latest updates.
        Failed to load resource: the server responded with a status of 404 (Not Found)
        http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2 Failed to load resource: the server responded with a status of 404 (Not Found)
        http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff Failed to load resource: the server responded with a status of 404 (Not Found)
        http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.ttf Failed to load resource: the server responded with a status of 404 (Not Found)
        http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css Failed to load resource: the server responded with a status of 404 (Not Found)
        http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:206 Error on loading stylesheet: vendor/css/font-awesome.css
        http://localhost:8080/vendor/node_modules/moment/min/moment-with-locales.js Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:190 Error on loading script: vendor/node_modules/moment/min/moment-with-locales.js
        http://localhost:8080/vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:190 Error on loading script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
        http://localhost:8080/vendor/node_modules/weathericons/css/weather-icons.css Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:206 Error on loading stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
        clock.js:49 Uncaught ReferenceError: moment is not defined
        clock.js:77 Uncaught (in promise) ReferenceError: moment is not defined(…)
        (repeat latest error again and again)
        thanks for your kind help
        Adrian
          Adrian_O
          1032:0418/181017:ERROR:CONSOLE(0)] “Font from origin ‘http://localhost:8080’ has been blocked from loading by Cross-Origin Resource Sharing policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource. Origin ‘chrome-devtools://devtools’ is therefore not allowed access. The response had HTTP status code 404.”, source: chrome-devtools://devtools/bundled/inspector.html?remoteBase=https://chrome-devtools-frontend.appspot.com/serve_file/@f33d44362232c20d1ce2111c53ea8730698f3c88/&can_dock=true&toolbarColor=rgba(223,223,223,1)&textColor=rgba(0,0,0,1)&experiments=true (0)
            sdetweil @Adrian_O
            @Adrian_O can u do
            in MM folder
            ls fonts -laF
            did u do sudo npm install?
              oh, and can u show the config entry for
              var config = {
                address: "0.0.0.0", //
              spammers have ruined everything…
              there is a security check now… localhost == 0.0.0.0 when false, results in the cross-site-scripting rejection
                what modules did u install? beyond the defaults?
