    PIR motion sensor/ pi root folder
    7 Posts 2 Posters 2.2k Views 2 Watching
      BandNerd1002
      Does anyone have a good tutorial waking through how to set up a PIR motion sensor with the MagicMirror. all of the ones that I have found either don’t work, or they crash the entire thing, and i have to restart completely. Any help? Also what is the pi home root folder?
        sdetweil @BandNerd1002
        @BandNerd1002 users home folders are in /home
        Then by user name, so pi
        So the home folder for user pi is
        /home/pi
          BandNerd1002
          Oh ok. Thank you
            @BandNerd1002 on the PIR, after u git clone, you have to go into the MMM-Pir folder and do npm install to add that modules dependencies.
            Any module that has a package.json needs the same npm install done from it’s module folder
              BandNerd1002
              Is there a good module to use? the ones that I have used always come up with a config error, or crash the pi.
                @BandNerd1002 see the step above about dependencies, and use the check:config
                i don’t use pir myself, i use a webcam for motion
                  BandNerd1002
                  Ok. Thank you.
