    MMM-AssistantMk2 youtube : start video
    5 Posts 5 Posters 3.9k Views 5 Watching
      MisterT
      i use MMM-AssistantMk2 and it’s awesome but i have a problem with youtube and start video. If i say: Smooth criminals Mickael Jackson, a youtube window open but nothing appened. Just a black screen with youtube logo
      I open console and there are errors but i don’t undestand. See below:
      www-widgetapi.js:99 Error while parsing the 'allow' attribute: 'accelerometer;', 'autoplay;', 'encrypted-media;', 'gyroscope;', 'picture-in-picture' are invalid feature names.
      mb @ www-widgetapi.js:99
      :8080/modules/MMM-AssistantMk2//MMM-AssistantMk2.js:744 Uncaught TypeError: console.log is not a function
          at onReady (:8080/modules/MMM-AssistantMk2//MMM-AssistantMk2.js:744)
          at P.k.H (s.ytimg.com/yts/jsbin/www-widgetapi-vflf9U9oY/www-widgetapi.js:54)
          at Y.k.s (s.ytimg.com/yts/jsbin/www-widgetapi-vflf9U9oY/www-widgetapi.js:98)
          at Y.k.I (s.ytimg.com/yts/jsbin/www-widgetapi-vflf9U9oY/www-widgetapi.js:112)
          at kb.g (s.ytimg.com/yts/jsbin/www-widgetapi-vflf9U9oY/www-widgetapi.js:87)
          at g (s.ytimg.com/yts/jsbin/www-widgetapi-vflf9U9oY/www-widgetapi.js:76)
      I post my config.js below with MMM-AssistantMK2 and MMM-Hotword:
          			module: "MMM-AssistantMk2",
          			deviceLocation: {
            					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
              				latitude: xx.xxxx, // -90.0 - +90.0
              				longitude: x.xxxx // -180.0 - +180.0
          			profiles: {
            				"default" : { // profile name.
              					profileFile: "default.json", // profile file name.
              					lang: "fr-FR"
              					//currently available (estimation, not all tested):
              					//  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
              					// fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
              					// https://developers.google.com/assistant/sdk/reference/rpc/languages
            			record: {
              		recordProgram : "arecord",
              		device        : "plughw:1",
      			play: {
            			playProgram: "mpg321", // recommended.
      			transcriptionHook: {
              			HIDE_ALL_MODULES: {
                  				pattern: "cache les modules",
                  				command: "HIDEMODULES"
                			SHOW_ALL_MODULES: {
                  				pattern: "affiche les modules",
                  				command: "SHOWMODULES"
                			SCREEN_ON: {
                  				pattern: "allume l'écran",
                  				command: "SCREENON"
                			SCREEN_OFF: {
                  				pattern: "eteins l'écran",
                  				command: "SCREENOFF"
                			REBOOT: {
                  				pattern: "reboot le miroir",
                  				command: "REBOOT"
                			SHUTDOWN: {
                  				pattern: "eteins le miroir",
                  				command: "SHUTDOWN"
                			STOP_PLAY: {
                  				pattern: "arrête la video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                  				command: "STOP_VID"
               			// STOP_PLAY2: {
               			//   pattern: "arrête la musique",
              			//   command: "STOP_VID"
      	 			SPOTIFY_PREVIOUS: {
              				pattern: "musique précédente",
              				command: "SPOTIFY_PREVIOUS"
              			SPOTIFY_PAUSE: {
              				pattern : "stop",
              				command: "SPOTIFY_PAUSE"
              			SPOTIFY_PLAY: {
              				pattern : "lance la musique",
              				command: "SPOTIFY_PLAY"
              			SPOTIFY_NEXT: {
              				pattern: "musique suivante",
              				command: "SPOTIFY_NEXT"
              			SPOTIFY_VOLUME: {
              				pattern: "met le volume à ([0-9]{1,2}[0]?|100)",
              				command: "SPOTIFY_VOLUME"
              			SPOTIFY_SEARCH: {
              				pattern: "joue (.*) on Spotify",
              				command: "SPOTIFY_SEARCH"
      				SPOTIFY_SEARCH_PLAYLIST: {
              				pattern: "playlist (.*) sur Spotify",
              				command: "SPOTIFY_SEARCH_PLAYLIST"
      				SPOTIFY_MA_PLAYLIST: {
      					pattern: "(.*) ma playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
      					command: "SPOTIFY_MA_PLAYLIST"
      				SPOTIFY_TRANSFER: {
      					pattern: "joue la musique sur (.*)", // (.*)  is the name of your device
      					command: "SPOTIFY_TRANSFER"
                			VOLUME_UP: {
                  				pattern: "augmente le volume",
                  				command: "CMD_VOLUME_UP"
                			VOLUME_DOWN: {
                  				pattern: "baisse le volume",
                  				command: "CMD_VOLUME_DOWN"
                			SET_VOLUME: {
                  				pattern: "met le volume global à ([0-9]{1,2}[0]?|100)",
                  				command: "CMD_VOLUME_SET"
              		command: {
                			STOP_VID: {
                  				moduleExec: {
                    						module: ["MMM-AssistantMk2"],
                    						exec: (module, params, key) => {
                      									module.assistant.subdom.youtube.innerHTML = "";
                      									module.assistant.subdom.youtube.style.display = "none";
                      									module.youtubePlaying = false;
      	   			SPOTIFY_TRANSFER: {
      	    				notificationExec: {
                    							notification: "SPOTIFY_TRANSFER",
      	         						payload: (params) => {
                       									console.log("SPOTIFY_TRANSFER @",params)
                      									return params[1];
                 			SPOTIFY_PAUSE: {
                  				notificationExec: {
                    							notification: "SPOTIFY_PAUSE"
              			SPOTIFY_PLAY: {
                  				notificationExec: {
                      						notification: "SPOTIFY_PLAY"
      	    				notificationExec:  {
      							notification: "SPOTIFY_PLAY",
      							console.log("SPOTIFY_MA_PLAYLIST")
      							return {
      								context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
      							notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
      							notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
      				SPOTIFY_NEXT: {
               				notificationExec: {
              			SPOTIFY_PREVIOUS: {
               				notificationExec: {
                  							notification: "SPOTIFY_PREVIOUS"
              			SPOTIFY_VOLUME: {
                  				notificationExec: {
                 							notification: "SPOTIFY_VOLUME",
                       								console.log("SPOTIFY_VOLUME @",params)
                      								return params[1];
      				SPOTIFY_SEARCH: {
               				notificationExec: {
                 							notification: "SPOTIFY_SEARCH",
                      						console.log("SPOTIFY_SEARCH @",params)
                      						return {
                              						type: "artist,track,album,playlist",
                              						query: params[1],
                              						random:false,
               				notificationExec: {
                      						console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                      						return {
                              						type: "playlist",
                              						query: params[1],
                              						random:true,
                			CMD_VOLUME_UP: {
                  				notificationExec: {
                    						notification: "VOLUME_UP"
                			CMD_VOLUME_DOWN: {
                  				notificationExec: {
                    						notification: "VOLUME_DOWN"
                			CMD_VOLUME_SET: {
                  				notificationExec: {
                    						notification: "VOLUME_SET",
                    						payload: (params, key) => {
                      								console.log("@", params);
                      								return params[1];
            			notifications: {
              			ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
              			ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      			responseVoice: true,
      			screenDuration: 5000,
      			youtubeAutoplay: true, //If set as true, found Youtube video will be played automatically.
          			pauseOnYoutube:true, //If set as true, You cannot activate Assistant during youtube playing. Recommended for the performance (Because permanent hotword detecting might make performance lower)
          			youtubePlayerVars: { // You can set youtube playerVars for your purpose, but should be careful.
            			"controls": 0,
            			"loop": 1,
            			"rel": 0,
          			youtubePlayQuality: "default", //small, medium, large, hd720, hd1080, highres or default
          			module: "MMM-Hotword",
          			snowboy: [
          					hotwords: "smartmirror", //this will be sent to other module for distinguishing which hotword is detected.
          					file: "resources/models/smart_mirror.umdl",
          					sensitivity: '0.5',
          					//hotwords: "snowboy",
          					//file: "resources/models/snowboy.umdl",
          					//sensitivity: '0.5',
          					file: 'resources/models/jarvis.umdl',
          					sensitivity: '0.8,0.80',
          					hotwords: ['jarvis','jarvis'] //Kitt.ai changed their Jarvis UMDL, it has 2 models in one file. So weird.
          					//anyway, you can give different name for each. ['jarvis_1', 'jarvis_2']. Even though I think this is useless.
          			record: {
            				device        : "plughw:1"
          			autostart:true,
          			onDetected: {
            					notification: (payload) => {
              								return "ASSISTANT_ACTIVATE"
            					payload: (payload) => {
              							return {
                								profile: payload.hotword
      Can you help me please?
      thanks for next answers
      J mumblebajM 2 Replies Last reply Reply Quote 0
        juantata @MisterT
        @MisterT said in MMM-AssistantMk2 youtube : start video:
        arrête la video
        Hi. I have the same problem. Did you fix it?
        • mumblebajM
          mumblebaj Module Developer @MisterT
          MMM-AssistantMk2
          I believe from other issues posted on the forum that in the MM-AssistantMk2.js file the console.log entries should be changed to Log.log. I think there are 8 entries in the file that need changing.
          • V
            vschinazi @juantata
            @juantata Did you ever manage to figure this out. I’m having a similar problem. When I query for a video with Google Assistant it tells me that it found it but it does not play it. In fact, GA freezes.
              mattx38 @mumblebaj
              @mumblebaj Hello, did you fix it ? I got kind of same issue…
