    Vertical Image Diagonal Line Issue
    imageresolution
    13 Posts 2 Posters 5.7k Views 2 Watching
      mfruckus @sdetweil
      @sdetweil I’m really new to all of this so I’m not 100% certain if I am or not. Is there a way that I could check?
        sdetweil @mfruckus
        @mfruckus i have never done this so, searching yields this
        http://www.raspberryconnect.com/gamessoftware/item/314-trying_out_opengl_on_raspberry_pi_3
          mfruckus @sdetweil
          @sdetweil Thanks for the info. I’m going to give it a shot and I’ll come back with results.
          cheers
            mfruckus
            I tried out all of the options (Full Kernel, Fake Kernel, and Legacy).
            For some reason, using the Full Kernel and the Fake Kernel somehow disregards my /boot/config.txt which tells it to rotate vertically. Changing the value and rebooting does nothing. I’m only able to be vertical at all when using Legacy.
            I’m fairly confounded as to why I’m not even able to get the display vertical with Full KMS and Fake KMS. My hunch is that it may not be of huge importance to my diagonal line issue.
            Even when using Legacy, if the display is horizontal, there’s no diagonal lines. It seems that it just wants to divide the vertical screen with a couple diagonal lines. There must be a solution though.
              mfruckus @mfruckus
              I’ve also tried installing just a clean raspbian stretch. However, the problem persists when I rotate the display with only the desktop environment of stretch running.
              I’m now thinking that the 32" Samsung I’m using may be the issue and I’m going to try out another make/model.
                mfruckus
                At this point, from what I’ve read, the issue of the screen tearing when vertical seems to be related to using the legacy driver. Supposedly a switch to Full KMS should work but I need to rotate my screen using xrandr. Can anyone give me the breakdown on using xrandr to rotate my screen vertically?
                Would be supremely appreciated
                  sdetweil @mfruckus
                  @mfruckus see
                  https://askubuntu.com/questions/95812/how-can-i-rotate-my-display-in-the-most-easy-way/95825
                    mfruckus @sdetweil
                    @sdetweil said in Vertical Image Diagonal Line Issue:
                    @mfruckus see
                    Thanks so much man. I got it working. This was the exact info I needed.
                    Rendering is still imperfect but there’s no screen tearing at all. Really really appreciate it. Going to post a detailed solution here shortly because this info is too hidden.
                      sdetweil @mfruckus
                      @mfruckus cool… i just did a google search to find that info… will be great if you post a step by step for others
                        mfruckus
                        Here’s a fix for screen tearing/graphical errors when you’ve rotated the screen to a vertical position.
                        First, you need to change your GL Driver to Full KMS. To do so, run:
                             sudo raspi-config
                        • Select Advanced Options
                        • Select GL Driver
                        • Select G1 GL (Full KMS) OpenGL desktop driver with full KMS
                        • Select Finish
                        • Reboot
                        Upon reboot, you’ll find your screen is horizontal.
                        To fix this, first run:
                             xrandr -q
                        You will be presented with a list of ports, the port that your monitor is connected to will say “connected.”
                        It should look something like this:
                        Screen 0: minimum 320 x 200, current 1080 x 1920, maximum 2048 x 2048
                        HDMI-1 connected 1080x1920+0+0 (normal left inverted right x axis y axis) 1210mm x 680mm
                        1920x1080i 60.0*+
                        1680x1050 59.8 60.0
                        1024x768 60.0
                        800x600 60.3 56.2
                        640x480 59.9
                        Composite-1 unknown connection (normal left inverted right x axis y axis)
                        720x480 62.69
                        In my instance, the port I need to know is HDMI-1. Yours may very well be different.
                        Now, using the name of the connected port, run:
                        xrandr --output (name of your connected port) --rotate right
                        My example would be:
                        xrandr --output HDMI-1 --rotate right
                        There you go! Now, your screen is vertical and not suffering from the awful screen tearing that it was. Not going to say it’ll look as good as it does horizontally but this fix vastly improved how my raspberry pi and MagicMirror looked when the screen is vertical.
                        I haven’t yet figured out how to make xrandr rotate on boot (any assistance there would be appreciated!) therefore, you’ll have to rotate the screen each time you boot it up.
                        When I do figure out how to make xrandr rotate upon boot, I’ll amend this guide!
                        Good luck, everybody!
