    MMM-GooglePhotos
    294 Posts 56 Posters 409.5k Views 59 Watching
      mirrorman2
      Brilliant module - thanks for the development.
      I am trying to get two instances of this module running on one magic mirror, so I can show one photo at the top and one at the bottom.
      I have copied the module into a different folder, renaming it (and in the CSS files as necessary). I also set up a separate google API project and separate authorisation to see if that was an issue.
      Both modules run, but the photos get loaded one on top of the other despite having different positions:
        module: "MMM-GooglePhotos",
        position: "top_center",
          albumId: "blanked for posting", // your album id(s) from result of `auth_and_test.js`
          refreshInterval: 1000*20,
          scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
          //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
          sort: "random", //'time', 'reverse', 'random'
          showWidth: "800px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
          showHeight: "400px",
          originalWidthPx: 1024, // original size of loaded image. (related with image quality)
          originalHeightPx: 728, // Bigger size gives you better quality, but can give you network burden.
          mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
          //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
        module: "MMM-GooglePhotos2",
        position: "bottom_left",
          refreshInterval: 1000*15,
          showWidth: "1024px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
          showHeight: "728px",
      Any ideas where I have gone wrong? Thanks!
      ? 1 Reply Last reply
        A Former User @mirrorman2
        @mirrorman2
        Each instance would be rendering different doms but they have same “Id”. That would make this behavior. Sorry, I haven’t considered duplicated instances on development.
        If you want duplicated instances, modify source where “id” is used.
        By example;
        wrapper.id = “GPHOTO”
          stephaniesal
            A Former User @stephaniesal
            @stephaniesal
            Is there any error or suspicious log message on execution? Without log, I cannot guess what happened.
              stephaniesal @Guest
              • G
                gekberlin
                Hi there,
                is it possible just to show the last three images of the given album ? And moreover is there any chance to display the comments which belongs to the photo ?
                  A Former User @gekberlin
                  @gekberlin
                  1. Cannot limit the number currently. And I thought, If you want just a few pictures, you’d better to store your photos locally and to display them with other local-based module.
                    The better way I think is, to create new album for selected photos and use it.
                  2. There is no API to get comment. Sorry.
                    redink
                    Thank you for making this great module and a very a good set of instuctions. I am struggling with the last step.
                    I run the node auth_and_test.jsand it opens the browser windows asking me to login. I proceed to do that, go through my 2FA and then land on a page which is asking me to select a google account form a list of 1 (just my account). Clicking my account just redirects me back to the same exact page. Have you seen this issue before? Any idea on how to fix this?
                      A Former User @redink
                      @redink Somebody has same issue. Copy the URL and use another browser. (Or another device - like your dev pc). I think it could be some kind of cookie issue.
                      R 1 Reply Last reply
                        redink @Guest
                        Thanks for the quick reply. I assumed this had to happen from the exact same machine that MagicMirror was running out, because it would set a local cookie or something. But, I’ll try opening the URL from a different machine and report back tonight.
                          redink
                          It worked! Thanks!
                          Is there a config to fade the picture, or do an 50% transparent black overlay? I am sure I can do this with some custom CSS, but was wondering of the module supports it.
                            @redink adjust css. i prefer to control looks by css.
                              redink
                              Thanks!
                              For anyone who wants to do the same, just add the following to your custom.css file
                              #GPHOTO{
                                   /*1 is fully opaque, 0 is fully transparent*/
                                  opacity: 0.3 !important;
                              • WasupDudeW
                                WasupDude Banned
                                wow, that’s really interesting ;)
                                • K
                                  King321
                                  Is there a way to have videos play as well?
                                  • O
                                    orayoflighto Project Sponsor
                                    First, thanks for a great module. Its greatly appreciated.
                                    Is there a way to prevent API requests during certain time periods? I have 14000 photos in an album that is only going to grow with time which is going to kill my API requests but I don’t need requests to take place at 2AM for instance.
                                      sdetweil @orayoflighto
                                      @orayoflighto do u put your mirror to sleep when u are not around? it should not fetch new images while mirror is asleep…
                                        A Former User @sdetweil
                                        @sdetweil @orayoflighto
                                        I’ll update(or build newly) about it on next patch.
                                        O 1 Reply Last reply
                                        • O
                                          orayoflighto Project Sponsor @Guest
                                          @Sean looking forward to it. Thanks again for an awesome module.
                                          @sdetweil I now have a cron job to turn the monitor off. Is that what you mean by “sleep”? Does that stop the API requests?
                                            @orayoflighto sadly no. The MagicMirror code doesn’t know the screen is off
                                            • 14
                                            • 15
                                            • 6 / 15
