    Compliments module is killing my other module.
    9 Posts 3 Posters 2.5k Views 3 Watching
      sunnykeerthi
      I am using compliments module and Widget module(MMM-Widget) together on the same screen. Compliments module basically refreshes every 30 sec. once 30 sec cycle ends(updateInterval), my module widget gets blank :frowning_face:
      Here is the widget module that I’m using. (this is the out of the box one that’s provided, I didn’t modify anything here. I changed the references in config.js file only).
      /* Magic Mirror
      * Module: MMM-Widget
      * By eouia
      const DefaultWidgetFormat = {
        url: "",
        width: "200px",
        height: "200px",
        backgroundColor: "#000"
      Module.register("MMM-Widget",{
        defaults: {
          widgets: []
        start: function() {
          this.sendSocketNotification("INIT", this.config)
        notificationReceived: function(noti, payload, sender) {
          if (noti == "DOM_OBJECTS_CREATED") {
            this.sendSocketNotification("START")
        socketNotificationReceived: function(noti, payload) {
          if (noti == "READY") {
            this.loadWidgets()
        loadWidgets: function() {
          var widgets = this.config.widgets
          for (i in widgets){
            var widget = Object.assign({}, DefaultWidgetFormat, widgets[i])
            var iFrame = document.createElement("iframe")
            iFrame.id = "WIDGET_" + i
            iFrame.className = "widget_item"
            iFrame.style.width = widget.width
            iFrame.style.height = widget.height
            iFrame.style.border = "none"
            iFrame.style.display = "block"
            iFrame.style.overflow = "hidden"
            iFrame.style.backgroundColor = widget.backgroundColor
            iFrame.scrolling = "no"
            iFrame.src = "/widget/" + i
            var position = "." + widget.position.replace("_", ".") + " > .container"
            var regionContainer = document.querySelector(position)
            regionContainer.appendChild(iFrame)
            if (regionContainer.style.display == "none") {
              regionContainer.style.display = "block"
        suspend: function() {
          var doms = document.getElementsByClassName("widget_item")
          if (doms.length > 0) {
            for (let dom of doms) {
              dom.style.display = "none"
        resume: function() {
              dom.style.display = "block"
      the compliments module that I’m using is also one that is provided out of the box.
      Here is my config file.
      			module: "compliments",
      			position: "top_center"
      			module: "MMM-Widget",
      				widgets: [
      						html: `
      								<a class="twitter-timeline" href="https://twitter.com/adidas?ref_src=twsrc%5Etfw" data-aria-polite="assertive">Tweets by Salesforce</a>
      								<script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script>
      						width: "400px",
      						height: "500px",
      						html: `
      								<!-- TradingView Widget BEGIN -->
      		<div class="tradingview-widget-container" >
      		  <script type="text/javascript" src="https://s3.tradingview.com/external-embedding/embed-widget-single-quote.js" async>
      		  "symbol": "NYSE:CRM",
      		  "width": "100%",
      		  "colorTheme": "light",
      		  "isTransparent": false,
      		  "locale": "en"
      		  </script>
      		</div>
      		<!-- TradingView Widget END -->
      						position: "bottom_left",
      						width: "400px",
      						height: "111px",
      						backgroundColor: "#FFF"
      please let me know on how can I fix this, this is very confusing.
      Also need some help on auto refreshing this MMM-Widget module for every 30 seconds to show latest feed.
      Thanks,
      Sunny
        sdetweil @sunnykeerthi
        @sunnykeerthi change the single quotes to double… u have the backtic… instead of single quote…
        just make all quotes the same
          sunnykeerthi
          Hey @sdetweil,
          Is that the real reason of this?
            i do not know… it is a 1st step
              sunnykeerthi
              Ah!!! Ohk @sdetweil , Thanks… I’ll update and post you back.
              Thanks!!!
                sunnykeerthi
                Hi @sdetweil ,
                Here is my update config.js.
                			position: "top_right"
                				widgets: [
                						html: "<a class=\"twitter-timeline\" href=\"https://twitter.com/adidas?ref_src=twsrc%5Etfw\" data-aria-polite=\"assertive\">Tweets by Adidas</a> <script async src=\"https://platform.twitter.com/widgets.js\" charset=\"utf-8\"></script>",
                						width: "400px",
                						height: "500px",
                But still no luck :frowning_face:
                @Module-Developers , @Sean any help please.
                  A Former User @sunnykeerthi
                  @sunnykeerthi
                  I’ll look inside tomorrow.
                    sunnykeerthi
                    Thanks very much @Sean :slightly_smiling_face:
                      @sunnykeerthi
                      I think it is fixed. Update and try again.
