    trouble using CSS to make a picture bigger
    3 Posts 2 Posters 1.2k Views 2 Watching
    • F Offline
      fnooah
      I have the MMM-Comic module installed and working on my mirror as shown here https://github.com/cowboysdude/MMM-Comic. Everything works great. But as he mentioned in the Repo that the comics may be too small. Which they were. So on i go to changing the custom.css files as he mentions. that works great. BUT now as all this was done in landscape mode on my mirror. I decided to rotate my display by changing the config.txt file of my Pi. Now the comic photo does not change in size no matter what i do. The module is in the lower_third region, and have also tried middle_center. Any suggestions on being able to see the comic?
      saljokeS 1 Reply Last reply Reply Quote 0
      • saljokeS Offline
        saljoke @fnooah
        @fnooah
        Hello
        You can try to use transform and scale on CSS to make it bigger.
        • F Offline
          fnooah
          @saljoke
          i actually was able to go to the module itself. I adjusted the .css file inside the module folder. It seems to work so far with no issues.
