    Serial Comunication with Arduino
    19 Posts 3 Posters 8.5k Views 3 Watching
      s.monti.74
      HI sdetweil, thanks
      I have connected my Arduino to RPi with USB cable and I read (on Arduino values of RFID tags) on the Serial monitor of Arduino IDE installed on my RPI
      Now I don’t understand which MMM Magic Mirror module I have to use to manage serial datas that I receive from Arduino
      thanks a lot
      bye
        sdetweil @s.monti.74
        @s-monti-74 I think u will have to create your own module
          How did u implement the pi side? Python?
            s.monti.74 @sdetweil
            mmmmmm… I’m using some MMM modules installed on my mirror, hoping that there is a module like MMM-ArduPort that I can use for my purpose
            :flushed_face:
              @s-monti-74 wht do you want to do with the rfid tag value? besides display it? use it as a profile id?
                s.monti.74
                Yes I want’t su use the tags as a profile ID and manage modules with MMM-ProfileSwitcher.
                so all the members of my family (each in possession of his tag), can have custom modules
                thank you very much for your advices
                  @s-monti-74 said in Serial Comunication with Arduino:
                  MMM-ProfileSwitcher
                  so, you would lookup the profile name from the rfid tag, and send a messge for that profile
                  from the MMM-ProfileSwitcher readme
                  this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
                    @s-monti-74 so, once again, what code running on the pi gets the rfid value?
                    python script or ???
                      s.monti.74
                      no code runs on the pi to get the value, the value is read from arduino from the tag and arduino sends the value to the pi via serial. i don’t know which module of magic mirror I have to use to read that value and use it as a notification to switch the profile with MMM-ProfileSwitcher
                        ok, got it… you don’t KNOW if you got it in the pi yet…
                        this module should work for you
                        https://github.com/Tom-Hirschberger/MMM-Serial-Notifications
                          s.monti.74
                          thanks a lot sdetweil
                            @s-monti-74
                            I think the module will read the serial port , and map that to some notification for other modules
                            devices: {
                                    '/dev/ttyACM0': {
                                      messages: {
                                        'Gesture: UP': [    < ---- message it reads from serial port (in your case rfid tag value)
                              @sdetweil YESSSS It works has I want, thanks again
                                @s-monti-74 way cool congrats!
