    Serial Comunication with Arduino
    19 Posts 3 Posters 8.4k Views 3 Watching
      Radek
      Hello, I am interested in displaying Serial communication between arduino and Magick Mirror.
      Something similar is used by MMM-Gesture but I have not been able to modify the code , I would like to display the numerical information from my arduino projects via USB serial.
      Does anyone use something like that?
      Thank you for advice.
        s.monti.74
        @Radek said in Serial Comunication with Arduino:
        MMM-Gestur
        Hi I have a similar need
        I wan’t to send notifications to Magic Mirror (to switch the profile) using an RFID sensor connected to an Arduino
        If I pass my personal tag near the RFID sensor connected to the Arduino, I want to switch the profile of magic Mirror
        Does anyone know if is possible to use the serial comunication in this way from arduino and RPi ?
          sure… serial is serial…
          arduino - write
          https://www.arduino.cc/en/serial/write
          pi - read (using on.data event)
          in node_helper.js
          https://github.com/nebrius/raspi-serial
          then the ‘on data’ event can signal the module if needed,
          with sendsocketnotification()
            s.monti.74
            so I abandon the idea of ​​using the arduino outputs (reduced to 3.3 volts) in the GPi input of the RPi and the mmm-buttons module?
            thank you very much
              sdetweil @s.monti.74
              @s-monti-74 yeh, just do serial communications…
                s.monti.74
                HI sdetweil, thanks
                I have connected my Arduino to RPi with USB cable and I read (on Arduino values of RFID tags) on the Serial monitor of Arduino IDE installed on my RPI
                Now I don’t understand which MMM Magic Mirror module I have to use to manage serial datas that I receive from Arduino
                thanks a lot
                bye
                  @s-monti-74 I think u will have to create your own module
                    How did u implement the pi side? Python?
                      s.monti.74 @sdetweil
                      mmmmmm… I’m using some MMM modules installed on my mirror, hoping that there is a module like MMM-ArduPort that I can use for my purpose
                      :flushed_face:
                        @s-monti-74 wht do you want to do with the rfid tag value? besides display it? use it as a profile id?
                          s.monti.74
                          Yes I want’t su use the tags as a profile ID and manage modules with MMM-ProfileSwitcher.
                          so all the members of my family (each in possession of his tag), can have custom modules
                          thank you very much for your advices
                            @s-monti-74 said in Serial Comunication with Arduino:
                            MMM-ProfileSwitcher
                            so, you would lookup the profile name from the rfid tag, and send a messge for that profile
                            from the MMM-ProfileSwitcher readme
                            this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
                              @s-monti-74 so, once again, what code running on the pi gets the rfid value?
                              python script or ???
                                s.monti.74
                                no code runs on the pi to get the value, the value is read from arduino from the tag and arduino sends the value to the pi via serial. i don’t know which module of magic mirror I have to use to read that value and use it as a notification to switch the profile with MMM-ProfileSwitcher
                                  ok, got it… you don’t KNOW if you got it in the pi yet…
                                  this module should work for you
                                  https://github.com/Tom-Hirschberger/MMM-Serial-Notifications
                                    s.monti.74
                                    thanks a lot sdetweil
                                      @s-monti-74
                                      I think the module will read the serial port , and map that to some notification for other modules
                                      devices: {
                                              '/dev/ttyACM0': {
                                                messages: {
                                                  'Gesture: UP': [    < ---- message it reads from serial port (in your case rfid tag value)
                                        @sdetweil YESSSS It works has I want, thanks again
                                          @s-monti-74 way cool congrats!
