    Serial Comunication with Arduino
    19 Posts 3 Posters 8.1k Views 3 Watching
      Radek
      Hello, I am interested in displaying Serial communication between arduino and Magick Mirror.
      Something similar is used by MMM-Gesture but I have not been able to modify the code , I would like to display the numerical information from my arduino projects via USB serial.
      Does anyone use something like that?
      Thank you for advice.
        s.monti.74
        @Radek said in Serial Comunication with Arduino:
        MMM-Gestur
        Hi I have a similar need
        I wan’t to send notifications to Magic Mirror (to switch the profile) using an RFID sensor connected to an Arduino
        If I pass my personal tag near the RFID sensor connected to the Arduino, I want to switch the profile of magic Mirror
        Does anyone know if is possible to use the serial comunication in this way from arduino and RPi ?
          sure… serial is serial…
          arduino - write
          https://www.arduino.cc/en/serial/write
          pi - read (using on.data event)
          in node_helper.js
          https://github.com/nebrius/raspi-serial
          then the ‘on data’ event can signal the module if needed,
          with sendsocketnotification()
            s.monti.74
            so I abandon the idea of ​​using the arduino outputs (reduced to 3.3 volts) in the GPi input of the RPi and the mmm-buttons module?
            thank you very much
              sdetweil @s.monti.74
              @s-monti-74 yeh, just do serial communications…
                s.monti.74
                HI sdetweil, thanks
                I have connected my Arduino to RPi with USB cable and I read (on Arduino values of RFID tags) on the Serial monitor of Arduino IDE installed on my RPI
                Now I don’t understand which MMM Magic Mirror module I have to use to manage serial datas that I receive from Arduino
                thanks a lot
                bye
                  @s-monti-74 I think u will have to create your own module
                    How did u implement the pi side? Python?
                      s.monti.74 @sdetweil
                      mmmmmm… I’m using some MMM modules installed on my mirror, hoping that there is a module like MMM-ArduPort that I can use for my purpose
                      :flushed_face:
                        @s-monti-74 wht do you want to do with the rfid tag value? besides display it? use it as a profile id?
