Unsolved MMM-GoogleAssistant autostart
auto install script sets up a pm2 module to start mirror app
yes, the mirror app starts flawlessly with all installed modules. The assistant icon appears on the mirror, but is not activated by “Ok google” unless I type the commands in my OP. I believe pm2 is controlling the Mirror autostart.
@poopyurinal ok, but if yoiu start it manually does it work?
pm2 stop MagicMirror
open a terminal window (ctrl-alt-t)
cd MagicMirror
npm startdoes it all work?
I don’t know assistant.py I assume it runs in the background… and somehow talks to the module… -
and with mirror running on boot, press ctrl-shit-i to open the developers window, and select the console tab, and scroll up to find any module errors
there is also a pm2 command to show its log… (I don’t use pm2 myself).
@poopyurinal said in MMM-GoogleAssistant autostart:
I know that to start the module successfully, I can enter the following 3 commands:
source env/bin/activate
cd ~/MagicMirror/modules/MMM-GoogleAssistant/pi
python3 assistant.pyyou are not starting the module… you are starting a background application
that is included in the module folderthe ‘module’ only runs inside the MagicMirror environment
so, you need to create a command that does the startup…
start the py and then start MMand then automate that
if u stop MM manually and restart it (without doing the assistant.py step) do the GA work thru mirror as u expect?
pm2 stop MagicMirror gives me:
[PM2][ERROR] Process MagicMirror not found
│ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
│ mm │ 0 │ fork │ online │ 1 │ 0% │ 2.5 MB │
Usepm2 show <id|name>
to get more details about an appAny thoughts? The MagicMirror is running. If I stop it by hitting Alt and closing it via the menu bar, it automatically restarts.
@poopyurinal pm2 list
pm2 list
to get more details about an app -
@poopyurinal pm2 stop mm
pm2 stop mm
[PM2] Applying action stopProcessId on app [mm](ids: 0)
[PM2] mm ✓
│ mm │ 0 │ fork │ stopped │ 1 │ 0% │ 0 B │
to get more details about an appSorry, limited by new user restriction of one post every 120 seconds
