    MMM-GoogleAssistant autostart
    46 Posts 3 Posters 31.6k Views 3 Watching
      sdetweil @poopyurinal
      @poopyurinal ok, make a two line script to execute both commands, and use that script as the exec script in the service
        poopyurinal
        Sorry, can you go into a little more detail on that? How would I create that script?
          @poopyurinal edit a new file, add the two lines to it, and save.
          The do
          chmod +x ????
          Where ??? is the name of the file you just created
          Then make that file name the name of the exec script.
            poopyurinal
            Do you mean a shell script? Or a python script?
              @poopyurinal shell script
                poopyurinal
                In the ExecStart field of the service, what is the command I need to run before the path? My shell script is in /home/pi/testerscript.sh. What command do I need to run that?
                  @poopyurinal edit the script again and add a new 1st line
                  #!/bin/sh
                  Because it is executable, the 1st line will be checked, and if the script processor is defined, it will be used
                  The default is also /bin/sh
                    poopyurinal
                    I edited the script as you suggested, but it is not starting after reboot. If I run it from the command line, I get:
                    pi@raspberrypi:~ $ /home/pi/testerscript.sh
                    /home/pi/testerscript.sh: 2: /home/pi/testerscript.sh: source: not found
                    File “/home/pi/MagicMirror/modules/MMM-GoogleAssistant/pi/assistant.py”, line 25, in
                    import google.oauth2.credentials
                    ImportError: No module named ‘google’
                    The part after the “Traceback” is the same error I got if I tried to run the /path/to/assistant.py without first running:
                    source /env/bin/activate
                    It seems like the shell script is not running the second command within the first. If I run source /env/bin/activate, my command line is preceded by (env). Is there some way to force that within the script?
                      @poopyurinal the shell script cannot find the command ‘source’.
                      so THAT is the 1st problem
                      try changing line 1 to
                      #!/bin/bash
                      to use bash instead of sh
                      I see the same problem here using sh
                        poopyurinal
                        Sorry for my delayed response, I didn’t have time to look into this yesterday.
                        Now I get:
                        /home/pi/testerscript.sh: line 2: /env/bin/activate: No such file or directory
                        S gauravsaccG 2 Replies Last reply
                          @poopyurinal I will have to work on this
                          • gauravsaccG
                            gauravsacc Module Developer @poopyurinal
                            @poopyurinal Have you looked into all closed issues on the github? https://github.com/gauravsacc/MMM-GoogleAssistant/issues/1
                              poopyurinal
                              I just looked at them but am not sure of the implications of them. I was able to get my magicmirror to work with MMM-googleassistant with one command via command line:
                              /home/pi/env/bin/python3 -u /home/pi/MagicMirror/modules/MMM-GoogleAssistant/pi/assistant.py
                              Does that help make it easier to autostart in another script? Definitely beyond my abilities at this point. I definitely appreciate your continued effort!
                                @poopyurinal said in MMM-GoogleAssistant autostart:
                                so, put that command as the 1st in the little script you wrote…
                                and the second command starts MM…
                                  poopyurinal
                                  I put that command in the script. What was the second part about starting MM? MM is already starting automatically via pm2. With just the quoted command in the script, after reboot, the GoogleAssistant is not functional. Do I need to restart MM after running this script? What is the command to do that?
                                  Thanks for your sustained help!
                                    poopyurinal
                                    I should also ask, do I need a “&” after any of these commands? I’ve seen that in some tutorials, but don’t fully understand when it is needed and when it is not.
                                      @poopyurinal ok, never mind on the mm…
                                      the & at the end of a command string means, spin that command off in the background and come back… to read another command
                                      if you do NOT have & at the end, then this command runs and all the rest wait til this command ends…
                                        poopyurinal
                                        My script now has these contents:
                                        #!/bin/bash
                                        But the Google Assistant does not work upon boot. If I run the command:
                                        after boot, from the command line, it starts. What can I do to fix this? It seems so close to working…
                                        • 2 / 3
