MMM-ResRobot - Public transport information for Sweden
Can you post your config? -
{ module: "MMM-ResRobot", position: "left", header: "Avgång", config: { from: "740015597", // ResRobot Station ID (or a comma-separated string of IDs) to: "740000002", // ResRobot Station ID of destination (or a comma-separated string of IDs) maximumEntries: 6, // Number of departures to show on screen truncateAfter: 5, // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation apiKey: "<key>" // Your ResRobot apiKey } },
@Notumlord
When I use your from: and to: I only get departures from Svingeln. I do get a lot of replies but cannot determine if they are all going in the same direction. As far as I can tell they are all departures from Svingeln, not arrivals.There is a comment in the documentation of the ResRobot API which states that in some situations duplicate data is returned (has to do with real time information). My guess is that it whas just something with the data.
If you want to troubleshoot you can uncomment the print of “body” in node_helper.js, this will print the json-reply from ResRobot.
@Alvinger
My mistake, here is the config:
to: "740098001"
Since this is from “Vagnhallen Gårda” to “Centralstaionen” it should only show Bus 60 with the title/destination “Masthugget”.While this does show up it also shows “Redbergsplatsen” which is the opposite direction.
Maybe this is intended?
It might be. I can’t control what replies ResRobot gives for a specific search. According to its documentation it should only return the result matching the from and to parameters. I’ll do some additionsl checking but you could try the search without a “to” valur to see if there is a difference.
Hi
Anyone got this working with Skånetrafiken bus traffic? so far I only get “fetching departures…” but someone said that I need to use their own API, not Trafiklabs, is that true? -
According to Trafiklab site Skånetrafiken is included in ResRobot so it should work.
did’nt work yesterday at all… now, I get a response but as of right now 16:16 it only shows one departure at 16:30 ?
{ module: "MMM-ResRobot", position: "right", header: "Femman", config: { from: "740015772", // ResRobot Station ID (or a comma-separated string of IDs) to: "740015577", // ResRobot Station ID of destination (or a comma-separated string of IDs) maximumEntries: 6, // Number of departures to show on screen truncateAfter: 5, // A value > 0 will truncate direction name at first space after <value> characters. 0 = no truncation apiKey: "407fe5c8-4621-4a20-a171-xxxxxxxxx" // Your ResRobot apiKey } },
edit:
sometimes only one departure shows up… after a while 5-6 shows… then it’s back to one. Will try different to: ID’s and see if I can get a better response
@MrH, ResRobot (Samtrafiken) had a service window between between 22.00 and 24.00 on October 10th. That was probably why you didn’t get a response then.
I will have a look this evening using your station ids.
Hi I’m in the making of building my Magic Mirror and came across this module. I have a problem that after roughly 7 hours it stops to update with the buss departures and freezes. Have anyone else had the same problem and found a solution to it? Works perfectly again after a restart but would like to find a solution to it.
