Unsolved Finding module classes
@sdetweil yes I found that too but putting this code in my custom.css file won’t change the follow of the name of the calendar? Am I doing it wrong?
Thanks again.calendar .titleClass {
Color: yellow}
@jakuk AND in addition, it goes in the config file where u defined your calendar entry
calendars: [ { symbol: "family ", url: "webcal://c....", titleClass: class_name ... and there are other classes for each part... },
and color is lowercase
@sdetweil said in Finding module classes:
It’s good practice, but css doesn’t care about upper/lowercase
Sorry i’m really confused now, in my config file i have this. I don’t have a titleClass, i have named the calendar under the header?
Do i just need to put color under the config ?}, { module: 'calendar', header: 'Family Calendar', position: 'top_left', fetchInterval: '30000', config: { calendars: [ { symbol: 'calendar-check-o', url: ******** } ], titleReplace: { 'De verjaardag van ': '', '\'s birthday': '' }, excludedEvents: [] } }, {
@jakuk you need to do two things, for each change
- add a css entry to specifically identify the behavior
- tell the calendar module to use your class
so, inside the calendar entry add the titleClass: class_name (step 1)
to the config (with appropriate commas etc)
you do NOT have to change the original class (if one is used, in case of title, none is specified)
see the calendar module readme
