    MMM-YouTube
    64 Posts 15 Posters 33.7k Views 16 Watching
      A Former User
      MMM-YouTube
      MagicMirror module for youtube player with runtime configuration and controllable by notification.
      Feature
      • Embedded YouTube Player on MagicMirror
      • Load and Play videos dynamically on runtime, not only statically by configuration.
      • Almost every YouTube iFrame APIs be supported.
      • Controllable by notification and callback
      • Controllable by MMM-TelegramBot command (You can send youtube video from Phone to MM via TelegramBot)
      Download and Details
      [card:eouia/MMM-YouTube]
      Note
      I know there be some of YouTube modules already, but nothing found to be controllable on runtime. So made it.
      J rafaelcotaR 2 Replies Last reply Reply Quote 1
        juantata @Guest
        @Sean Hi. After installing the module. When I start the MagicMirror I get this error
        magicmirror@2.8.0 start /home/pi/MagicMirror
        sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config …
        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: disabled is not defined
        at Object. (/home/pi/MagicMirror/config/config.js:86:14)
        at Object. (/home/pi/MagicMirror/config/config.js:210:3)
        at Module._compile (internal/modules/cjs/loader.js:711:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
        at Module.load (internal/modules/cjs/loader.js:620:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
        at Function.Module._load (internal/modules/cjs/loader.js:551:3)
        at Module.require (internal/modules/cjs/loader.js:658:17)
        at require (internal/modules/cjs/helpers.js:20:18)
        at loadConfig (/home/pi/MagicMirror/js/app.js:64:12)
        Loading module helpers …
        No helper found for module: helloworld.
        All module helpers loaded.
        Starting server on port 8080 …
        Server started …
        Sockets connected & modules started …
        Launching application.
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @juantata
          @juantata can u paste your config here, three back-tics before and after
            A Former User @juantata
            @juantata
            Sorry, there was my mistake. I left my experimental codes on config example. I fixed the README. Back to the page and copy again (Just remove disabled:disabled["MMM-Youtube"], line.)
              juantata @Guest
              @Sean I say: YouTube Michael Jackson Thriller. And the answer is
                juantata @sdetweil
                @sdetweil {
                module: “MMM-YouTube”,
                position: “top_center”,
                verbose:true,
                defaultQuality: “default”,
                disableCC: true,
                showPlayingOnly: true,
                defaultLoop: false,
                defaultShuffle: false,
                defaultAutoplay: true,
                onStartPlay: null,
                playerVars: {
                controls: 0,
                hl: “en”,
                enablejsapi: 1,
                showinfo: 0,
                rel: 0,
                cc_load_policy: 0,
                outNotifications: {
                “-1”: “UNSTARTED”,
                “0”: “ENDED”,
                “1”: “PLAYING”,
                “2”: “PAUSED”,
                “3”: “BUFFERING”,
                “5”: “VIDEO CUED”,
                  @juantata it seems not allowed. some clips are limited by right owner not to be played out of youtube
                    sdetweil @juantata
                    @juantata forgot the 3 backticks before and after
                      juantata @sdetweil
                      @sdetweil said in MMM-YouTube:
                      backticks
                      Sorry but I’m a newbie. What do you mean with the three backticks?
                        sdetweil @juantata
                        @juantata on the US keyboard, shifted key left of the number 1 ` (like single quote, but leaning to the left) . the non shifted symbol is tidle ~
                        see https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet
                        Code and Syntax Highlighting
                        • mumblebajM Offline
                          @sdetweil I thought it was the other way around? Tilda (~) was shifted and back tick (`) non shifted? :smiling_face_with_open_mouth_smiling_eyes:
                            sdetweil @mumblebaj
                            @mumblebaj maybe, my keyboard has them labeled backwards
                              juantata @sdetweil
                              Hi. I don’t know where it could be wrong. I have copied it the same.
                                @juantata
                                I don’t know Spanish at all, Anyway “El video no esta disvonible” looks like “The video is not available”
                                The reason would be various.
                                • The clip is removed (sometimes it is searchable but not playable)
                                • The clip is not allowed to be played outside of YouTube websites by it’s right owner. (I don’t know why owners restrict their clip, but some did)
                                Anyway, that is not the issue of module itself.
                                  juantata @Guest
                                  @Sean Hi. It asks me to update. How is it done?
                                    @juantata ???
                                      juantata @Guest
                                      @Sean An update is available for the MM-Youtube module.
                                      Your current installation is 1 commint changes behind the master branch.
                                        juantata @Guest
                                          @juantata Go to MMM-YouTube directory then do the command git pull, but the update was not so important so you can ignore it.
                                            juantata @Guest
                                            @Sean Hi. I’m sorry to give you the can so much.
                                            To call the youtube module I say:
                                            Ok google + singer’s name + song title, and the result is this
                                            The result is the same with any video I request.
                                            • 1 / 4
