    MMM-AssistantMK2 USB Mic
    4 Posts 3 Posters 2.3k Views 2 Watching
    • T
      tigroufou
      Hi, thanks to be cool with me.
      I’m French and my English isn’t very good :-)
      I have install and configure MagicMirror with MMM-AssistantMK2.
      But the USB microphone and USB audio doesn’t work.
      I don’t understand where is the problem ?
      This is arecord List
      pi@raspberrypi:~ $ arecord -L
      null
          Discard all samples (playback) or generate zero samples (capture)
      default
      sysdefault:CARD=Device
          USB PnP Sound Device, USB Audio
          Default Audio Device
      front:CARD=Device,DEV=0
          Front speakers
      surround21:CARD=Device,DEV=0
          2.1 Surround output to Front and Subwoofer speakers
      surround40:CARD=Device,DEV=0
          4.0 Surround output to Front and Rear speakers
      surround41:CARD=Device,DEV=0
          4.1 Surround output to Front, Rear and Subwoofer speakers
      surround50:CARD=Device,DEV=0
          5.0 Surround output to Front, Center and Rear speakers
      surround51:CARD=Device,DEV=0
          5.1 Surround output to Front, Center, Rear and Subwoofer speakers
      surround71:CARD=Device,DEV=0
          7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
      iec958:CARD=Device,DEV=0
          IEC958 (S/PDIF) Digital Audio Output
      dmix:CARD=Device,DEV=0
          Direct sample mixing device
      dsnoop:CARD=Device,DEV=0
          Direct sample snooping device
      hw:CARD=Device,DEV=0
          Direct hardware device without any conversions
      plughw:CARD=Device,DEV=0
          Hardware device with all software conversions
      And this is .asoundrc configuration file
      pcm.!default{
        type hw
        playback.pcm{
          type hw
          card 1
        capture.pcm{
          type plug
          slave.pcm "hw:1, 0"
      ctl.!default{
        type hw
        card 1
      pcm.!default {
      	type hw
      	card 1
      ctl.!default {
      	type hw
      	card 1
      Even if i configure by Default USB Soundcard (USB Pnb sound Device) in “Preferences/Audio Device Setting”, it doesn’t work too.
      Have you any solution for me ?
        bhepler Module Developer
        Please use the markdown features of the board when posting code.
        • T
          tigroufou
          I have modified with markdown features.
            solomon-il
            I went through this tutorial and managed to use USB Mic:
            link text
