    Using the Raspberry Pi Camera to see through the mirror
    24 Posts 7 Posters 29.7k Views 7 Watching
      broberg Project Sponsor
      Do consider that there is difference in properties between the types of two way mirrors out there,
      one type could work well with a camera lens while another type doesn’t work at all.
      for an example many two way coatings are made to filter out IR light.
        Synthic @broberg
        @broberg That is a valid point. How would one know what kind of two-way mirror I posess? Haven’t been able to find any “comprehensive overview” of two-way mirrors
          dpenney @Synthic
          @Synthic Infrared is blocked by cameras anyway so that wouldn’t make a difference. The only thing the camera cares about is visible light so if you are able to see through the mirror you are using then there is no reason that the camera shouldn’t be able to do the same thing regardless of what material the mirror is made from.
          I too have the basic PiCam located behind the glass and it works perfectly. Does your cam work without the glass in place?
            Synthic @dpenney
            @dpenney That’s what bugs me:
            1. The PiCamera works great normally
            2. I can see through the mirror
            3. My Nexus 5 camera can see through the mirror
            4. The PiCamera can not. (it CAN, but it is waaaay too dark)
            D B 2 Replies Last reply Reply Quote 0
              dpenney @Synthic
              @Synthic That is frustrating…
              I think the facial recognition module uses python-picamera to talk to the camera, are you able to tweak the configs somewhere in order to up the brightness?
              https://www.raspberrypi.org/documentation/usage/camera/python/README.md
                dpenney
                This is where the camera is setup - try adding
                camera.brightness = 90
                https://github.com/paviro/MMM-Facial-Recognition/blob/master/facerecognition/picam.py
                Worth a shot :)
                  broberg Project Sponsor @Synthic
                  @Synthic I can tell you that my nexus 5 camera does not like my glass at all, al tough, the light transmission on my mirror is really low.
                    Synthic @dpenney
                    @dpenney This is my setup:
                    alt text
                    This photo is with normal camera:
                    alt text
                    This photo with PiCamera:
                    alt text
                    With brightness=90, I tried screwing around with most settings without result.
                    alt text
                      dpenney
                      Yeeesh that is dark - although even the pic with the normal camera is really dark. Much less contrast than I was getting, perhaps you do have a bad camera as the quality definitely shouldn’t be that poor.
                        JonoGee @Synthic
                        @Synthic
                        Hi Synthic, Please may I ask what module you used to display the PiCam feed in MagicMirror?
                        Regards
                        • L Offline
                          lolobyte @Synthic
                          @Synthic Hi, here my cam through my mirror on daytime and with lights and my setup. All pictures later…
                          This one cam through mirror with lights.
