    MMM-AssistantMk2 terminating and not activating by voice after that.
    13 Posts 5 Posters 5.4k Views 5 Watching
      blee1997
      Would this error only occur when saying the Activation word or would it time out after 10-15 seconds and show you the error. I also encountered a similar error message but not sure on what is happening either.
        A Former User
        you might have not assigned the position of hotword module.
          BJ Duncan
          @blee1997 - It would not acknowledge or activate when I say “smart mirror”, “hey google” or anything. I am not even sure how to set that actual activating word/s. I assumed the default was “smart mirror”. But if I click the icon with the mouse it will listen to anything and interpret anything I say including the above mentioned words.
          @Sean - Looking through the config.js it doesn’t appear to have position, so I will give that a go also.
          Thanks for replying and I will keep at it and will reply once I have a solution.
          Regards,
          BJ Duncan
          Regards,
          BJ Duncan
            BJ Duncan
            So I’m almost there now. I realised that I had the incorrect data within my config.js file as I used the configuration for v1 rather than v2. I also added the same position as the MMM-AssistantMk2 with the config.js (thanks to @Sean for that ;-) )
            My only issue now is that it still seems to terminate before completing the return request.
            E.g.
            Me: “Smart Mirror, what is the time?”
            (OSD: “what is the time?”)
            AssistantMk2: “The time is 8” - terminates
            (OSD: returns back to original icon immediately after termination.)
            – no ererors appear when I run this in dev mode –
            This occurs after each attempt regardless of the actual question. Could there possibly be a conflict with another module? Has anyone else come across this issue?
            Regards,
            BJ Duncan
            Regards,
            BJ Duncan
              sdetweil @BJ Duncan
              @BJ-Duncan thats funny… it used to chop off the beginning of the reply… !
              B 1 Reply Last reply
                BJ Duncan @sdetweil
                @sdetweil Is there some setting I need to adjust to allow it to complete the request? Have I inadvertently changed a default setting somewhere?
                Regards,
                BJ Duncan
                  BJ Duncan
                  So I have been testing random things and I have noticed that if I ask it to tell me a joke, it actually completes that request. If I ask it for any type of information (eg. weather, time, who invented the telephone etc) that’s when it cuts off.
                  Could it be something to do with sending a request online?
                  Regards,
                  BJ Duncan
                    sdetweil @BJ Duncan
                    @BJ-Duncan no… he reworked the audio in V2 to behave better… but apparently hasn’t got it all working perfect yet…
                    I noticed before similar for you… long answers worked, short were clipped
                    • I
                      Ivanov_d
                      This is a known issue and it is tracked in https://github.com/eouia/MMM-AssistantMk2/issues/161#issuecomment-496287957
                      You can try the various solutions proposed by the developer of the module. I have the same issue and I am waiting for a fix as well.
                        A Former User
                        Today, I’ve reported from one of users, he says old mpg321 could clip the last part of response. try to update it or reinstall or, at least try other play program.
                          BJ Duncan
                          Thanks @Ivanov_d I found that link the other day and did try those solutions. They didn’t work for me.
                          However, I will try @Sean’s suggestion and will post back on the forum if it worked or not.
                          Thanks to everyone for your assistance. Very much appreciated.
                          Regards,
                          BJ Duncan
                          Regards,
                          BJ Duncan
                            BJ Duncan
                            @Sean said in MMM-AssistantMk2 terminating and not activating by voice after that.:
                            mpg321
                            Woo-Hoo! - Thank you so much @Sean - That worked for me. I just reinstalled (or maybe just installed) mpg321 and it is completing the whole sentence without any cutoff. #veryHapppy :-)
                            The code I used was:
                            sudo apt-get -y install mpg321
                            Thanks to all that contributed to this post and I hope it helps others out just as it helped me.
                            Regards,
                            BJ Duncan
                            Regards,
                            BJ Duncan
