MMM-Nest only showing a Blank Black Screen
4 Posts 3 Posters 2.3k Views 2 Watching
  • N Offline
    nbrenn
    When I entered the access token for the MMM-Nest Module, I am only seeing a blank black screen.
    When I comment out the Nest module, all of my other modules are working fine.
    I have my access token entered correctly, as far as I know. I’m just confused as to why I’d receive a blank black screen, with no other modules showing up either.
    Thanks for any ideas!
    • N Offline
      nbrenn
      I received the error:
      Load script: modules/MMM-Nest//MMM-Nest.js
      Failed to load resource: the server responded with a status of 404 (Not Found)
      What could be causing this error? A port issue? A token issue with the Nest API?
        andrewchumchal
          MichMich Admin
          It seems there is an error in your config. Could you post the MMM-Nest part of your config, without any access codes? Also, did you follow the MMM-Nest installation guide?
