Newsfeed "loading..."
9 Posts 3 Posters 2.0k Views 2 Watching
    DocVooDoo
    Hi Guys. I have a problem with the newsfeeds. If I set the ignoreOldItems option to true, I will no longer see any feeds. It is only Loading. I have already tried a reboot, in vain.
    Who can help me here? If I set the option to “false” the feeds are displayed directly to me.
    If I start with “server only” I get no error messages in this regard …
    https://pastebin.com/THDrSAVh <-- The Config from Newsfeed
    S 1 Reply Last reply Jun 21, 2019, 11:42 AM Reply Quote 0
      sdetweil @DocVooDoo
      @DocVooDoo open the developers window, ctrl-shift-i, and select the console tab, then scroll up to see if there are any errors… usually red text…
      let us know
      D 1 Reply Last reply Jun 21, 2019, 11:45 AM Reply Quote 0
        DocVooDoo @sdetweil
        @sdetweil Hi and thanks for the quick reply.
        Only one error …: Google Maps JavaScript API error: ApiNotActivatedMapError
        That’s from the module MMM-Fuel. I will remove the same.
        S 1 Reply Last reply Jun 21, 2019, 11:50 AM Reply Quote 0
          sdetweil @DocVooDoo
          @DocVooDoo ok, i changed mine to add that parm, and don’t see any different behavior… still get feed items displayed.
          D 1 Reply Last reply Jun 21, 2019, 11:52 AM Reply Quote 0
            DocVooDoo @sdetweil
            @sdetweil Is there a cache or something? Something cached? That’s really only if I activate this option …
            S 1 Reply Last reply Jun 21, 2019, 11:59 AM Reply Quote 0
              sdetweil @DocVooDoo
              @DocVooDoo no… no cache
                broberg Project Sponsor
                What is the limit for old headlines and does your newsfeed have actual current headlines? (i.e are there headlines newer than the set time limit)
                  Lookin at your config you have set that it should ignore headlines that are older than what, 4.5 minutes?
                  Change the ignoreOlderThan: to at least the default 1 day which is 86400000
                  D 1 Reply Last reply Jun 21, 2019, 7:07 PM Reply Quote 1
                    DocVooDoo @broberg
                    @broberg Oh, I have given seconds instead of milliseconds. Thank you for the hint !! now it works.
