    Monthly Calendar View
    58 Posts 23 Posters 91.1k Views 19 Watching
    • pjkoelemanP
      pjkoeleman
      @KirAsh4
      What I’am missing in the calendar is a colum with the weeknumbers, left of the dates.
      The weeknumbers could or should be an option ‘showWeekNr’ is true of false.
      This should not be too difficult to build into the calendar.
      just my thoughts
      • E
        erik72
        Is there any config.js language setting that will make it start on Monday ?
        Tried uk that gave me russian :)
        • F
          FangFace
          ‘en-GB’ worked for me
          E J 2 Replies Last reply
          • E
            erik72 @FangFace
            @FangFace Your golden, Thanks
            • KimzerK
              Kimzer @KirAsh4
              @KirAsh4 said in Monthly Calendar View:
              Oh I suppose …
              Keep in mind that the styling can be changed by the user to whatever they want it to look like. The sky isn’t the limit … it’s their imagination. :)
              can u post css for this?
              • Y
                yomaldyw @KirAsh4
                @KirAsh4 As mentioned above, how to configure magic mirror default calendar in monthly view. I eagerly await an answer from you :slightly_smiling_face: :slightly_smiling_face: :slightly_smiling_face:
                  sdetweil @yomaldyw
                  @yomaldyw see https://forum.magicmirror.builders/topic/238/monthly-calendar
                  Y 1 Reply Last reply
                  • Y
                    yomaldyw @sdetweil
                    @sdetweil yes thanks. I install it. but its not displaying
                    S K 2 Replies Last reply
                      sdetweil @yomaldyw
                      @yomaldyw worked for me out of the box… have to put it between date and calendar modules in the config list to get it to display there…
                      used the default config
                      				module: 'calendar_monthly',
                      				position: 'top_left',
                      						// The config property is optional
                      						// Without a config, a default month view is shown
                      						// Please see the 'Configuration Options' section for more information
                      • Y
                        yomaldyw @sdetweil
                        @sdetweil yes yes i got it. now its work wel, thank you so much.:smiling_face: :smiling_face: :smiling_face: :folded_hands: :folded_hands: :folded_hands: :thumbs_up: :thumbs_up: :thumbs_up: :thumbs_up: :handshake: :handshake: :handshake:
                          sdetweil @yomaldyw
                          @yomaldyw what did you do differently?
                          • F
                            Fifin404
                            Hi, is possible to make vertical highlight of weekwnds numbers of day? Something like this
                            ? 1 Reply Last reply
                              jfridolf @FangFace
                              @FangFace said in Monthly Calendar View:
                              How did you do this configuration?
                              I tried to add:
                              Language: “en-GB”,
                              to the config-part for the module, but it did nothing.
                                A Former User @Fifin404
                                • K
                                  KevinMM @yomaldyw
                                  • A
                                    abbadon89
                                    Where i can find running weekend module?
                                    • 3 / 3
