    MMM-Facial-Recognition-OCV3 cant run toold.capture.py
    5 Posts 3 Posters 2.5k Views 3 Watching
    • I Offline
      idmarco
      Hi!
      I followed the steps for installation. I have not had any problems.
      However, when I run the tools.capture.py file I get the following error.
      RESTART: /home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/tools.capture.py
      File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/tools.capture.py”, line 9, in
      from lib.tools.capture import ToolsCapture
      File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/tools/capture.py”, line 19, in
      from config import ToolsConfig
      ImportError: No module named ‘config’
      Can you help me?
        Sebi76
        Hello ,
        i had the same Problem. Clean Install from here…
        " https://github.com/normyx/MMM-Facial-Recognition-OCV3 "
        pi@raspberrypi:~/MagicMirror/modules/MMM-Facial-Recognition-OCV3 $ sudo python3 tools.capture.py
        File “tools.capture.py”, line 9, in
        ImportError: cannot import name ‘ToolsConfig’
          Sebi76
          I found the issue.
          Change in capture.py
          from config import ToolsConfig -> from .config import ToolsConfig
            SdeGeata @Sebi76
            @Sebi76 said in MMM-Facial-Recognition-OCV3 cant run toold.capture.py:
            Well this solved the first of two problems for me. I have been getting the same error on capture since i installed. Thanks!
            Now however, i get this error when trying to train:
            OpenCV Error: Assertion failed (ssize.width > 0 && ssize.height > 0) in resize, file /home/pi/opencv/modules/imgproc/src/imgwarp.cpp, line 3483
              File "tools.train.py", line 14, in <module>
                ToolsTrain().train()
              File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/tools/train.py", line 53, in train
                faces.append(self.prepareImage(filename))
              File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/tools/train.py", line 29, in prepareImage
                return self.face.resize(cv2.imread(filename, cv2.IMREAD_GRAYSCALE),ToolsConfig.FACE_WIDTH, ToolsConfig.FACE_HEIGHT)
              File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-OCV3/lib/common/face.py", line 113, in resize
                return cv2.resize(image, (face_width, face_height), interpolation=cv2.INTER_LANCZOS4)
            cv2.error: /home/pi/opencv/modules/imgproc/src/imgwarp.cpp:3483: error: (-215) ssize.width > 0 && ssize.height > 0 in function resize
            Any idea what that’s about???
              SdeGeata @SdeGeata
              @SdeGeata
              Nevermind, I just fixed it! It was an outdated PIP that wasn’t getting updated without SUDO.
              sudo pip install future --upgrade
