    Soccer Noob needs help!
    30 Posts 4 Posters 12.9k Views 4 Watching
    • evroomE Online
      evroom
      Peter,
      Personally I am using MMM-soccer for Eredivisie.
      Champions League should be free too…
      If needed can help you with the config.
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
        Peter @evroom
        @evroom Thanks! I will give it a try!
        Peter
        • evroomE Online
          evroom
          @Peter
          This is my config for de Eredivisie.
          It shows the first 9 teams from the standings and focuses on one team.
            module: 'MMM-soccer',
            disabled: false,
            position: 'top_right',
               api_key: 'your_api_key',
               colored: true,
               show: 'NETHERLANDS',
               focus_on: {
                 "NETHERLANDS": "AFC Ajax",
               max_teams: 9,
               logos: true,
               leagues: {
                  NETHERLANDS: 'DED',
                  EUROPE: 'CL',
          There are no logos for de Eredivisie included, so you will have to collect them yourself.
          They need to be placed under:
          /home/pi/MagicMirror/modules/MMM-soccer/public
          Test environment:
          • thedoorsfanaticT Offline
            thedoorsfanatic @Peter
            @Peter
            I use MMM-SoccerLiveScore and it runs pretty smoothly …
            https://youtu.be/5Cs3pCZamuM
            My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
              Peter @evroom
              @evroom I copied your config, used my own API: unfortunately it does not work.
              Who can help?
              Peter
              • evroomE Online
                evroom
                }, // end of last module
                { // start of MMM-soccer module
                  disabled: false,
                     colored: true,
                     focus_on: {
                     max_teams: 9,
                     logos: true,
                     leagues: {
                        NETHERLANDS: 'DED',
                        EUROPE: 'CL',
                }, // end of MMM-soccer module
                { // start of next module, if any.
                To check:
                cd ~/MagicMirror; npm run config:check
                Test environment:
                  Peter @evroom
                  @evroom Module is running, but no teams visible …
                  Peter
                  • evroomE Online
                    evroom
                    @Peter
                    I have MMM-SoccerLiveScore running now and it is looking nice.
                    It has all logos present already and the table is already present (just listed on alphabetic order as one would expect pre round 1).
                    Give it a try.
                    I now remember why I use(d) MMM-soccer.
                    MMM-SoccerLiveScore shows the scores by default and the standings can be turned off.
                    But I do not want to know the scores as it spoils watching Studio Sport and/or die Sportschau.
                    MMM-soccer just show the standings, nothing more (and even this spoils it some times).
                    If MMM-SoccerLiveScore would have an option like “showScores: false”, it would be perfect.
                    Test environment:
                    thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                      thedoorsfanatic @evroom
                      @evroom
                      Have you tried this one?
                      https://github.com/GHLasse/MMM-FootballTable
                      • evroomE Online
                        evroom @thedoorsfanatic
                        @thedoorsfanatic
                        No, I haven’t.
                        It looks a lot like MMM-soccer (code-wise, because there are no screenshots available), with the difference that it still uses v1, which probably will not work.
                        And I do not see the possibility for team-logos.
                        Do you use it ?
                        Does it work ?
                        Test environment:
