    Soccer Noob needs help!
    30 Posts 4 Posters 15.4k Views 4 Watching
    • thedoorsfanaticT
      thedoorsfanatic @evroom
      @evroom
      No, I use MMM-SoccerLiveScore myself and got it timed with MMM-ModuleScheduler so I don’t get spoiled before watching Sportschau ;)
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      evroomE 1 Reply Last reply
      • evroomE
        evroom @thedoorsfanatic
        @thedoorsfanatic
        Interesting.
        I do not use MMM-ModuleScheduler.
        Could you give an example on how to configure it for MMM-SoccerLiveScore ?
        Do you schedule it to NOT see it during a specific period, like Saturday from 15:30 to 20:00 ?
        MagicMirror version: 2.37.0
        • evroomE
          evroom
          @thedoorsfanatic
          I think I got it.
          Perhaps there is a better way, because I do not understand show, hidden and dim very good.
          I thought it would be easy to say “show from to”, “hide from to” or “dim from to”, but like this it seems to work:
            module: 'MMM-SoccerLiveScore',
            position: 'top_right',
            //header: 'Live-Scores',
            classes: 'scheduler',
              module_schedule: [
                {from: '45 22 * * *', to: '30 19 * * 6', dimLevel: '10'}, // dim Saturday from 19:30 to 22:45
                {from: '00 20 * * *', to: '30 13 * * 7', dimLevel: '10'}, // dim Sunday from 13:30 to 20:00
          //        {from: '00 20 * * *', to: '30 15 * * 6', dimLevel: '10'}, // dim Saturday from 15:30 to 20:00
              leagues: [37,],
          • evroomE
            evroom @evroom
            @thedoorsfanatic
            Nope, does not work.
            An example would be nice.
            thedoorsfanaticT 1 Reply Last reply
              Peter
              MMM-SoccerLiveScore worked out of the box!
              But after a few hours the module stops.
              Other modules keep going.
              Any body know the solution?
              Peter
              • evroomE
                evroom @Peter
                @Peter
                I do not have it running long enough to see this behaviour.
                But, if you see this with
                $ pm2 logs mm
                0|mm       | (node:22849) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                Do this (line 37):
                $ vi /home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                          //var image = new Buffer(body).toString('base64');
                            var image = Buffer.from(body).toString('base64');
                $ pm2 restart mm
                Then observe and pay attention to the pm2 logs.
                • evroomE
                  evroom
                  Just to say that MMM-SoccerLiveScore is running on my MM for 28 hours now.
                  @thedoorsfanatic
                  Still waiting for an example on hiding / dimming a module for a specific time on a specific day using MMM-SoccerLiveScore.
                  When you have time.
                  • thedoorsfanaticT
                    @evroom
                    I am a beginner from Germany with bad English and I am not using dimLevel at all.
                    To show a module just at a certain time I put this in the config of a module:
                        			module_schedule: {from: '30 6 * * 1-5', to: '45 7 * * 1-5' },
                    shows a module only from 6.30 h to 7.45 from Monday to Friday.
                    Just use this to figure out what range you need:
                    https://crontab.guru/#30-59_6_*_*_1-5
                    S evroomE 2 Replies Last reply
                      sdetweil @thedoorsfanatic
                      @thedoorsfanatic said in Soccer Noob needs help!:
                      module_schedule:
                      that only works for this one module…
                      not… MMM-ModuleScheduler appears to support showing/dimming or hiding modules based on time of day (cron style schedule)
                        Peter
                        MMM-SoccerLiveScore looks very nice, works fine, but still dissapears after some time.
                        Sometimes it comes back after a few minutes, sometimes not.
                        Nothing strange in the pm2 logs …
                        Peter
                        • evroomE
                          @thedoorsfanatic
                          I am Dutch living in Germany and I like Bad English, well the band :-)
                          Thanks for the example.
                          • evroomE
                            evroom @sdetweil
                            Do you know how to hide or dim a module between certain times.
                            For example, matches in Germany generally start on Saturday at 15:30 and the sports program ends at 20:00.
                            So I want to hide or dim the module during this time.
                            The problem with the scheduler is, that it shows at the from time and dims at the to time.
                            Cannot find an example where it hides/dims at the from time and shows at the to time.
                              sdetweil @evroom
                              @evroom no, sorry… this is module specific, not a general thing…
                              spounds like you could reverse the times
                              • evroomE
                                evroom @sdetweil
                                Do you mean ModuleScheduler.specific or the module to schedule specific, like MMM-SoccerLiveScore ?
                                I understood that schedules in the ModuleScheduler are generic (unless in the exclude list) for all modules and the schedules in a module are for that specific module.
                                  sdetweil @evroom
                                  @evroom said in Soccer Noob needs help!:
                                  never heard of this
                                  • evroomE
                                    evroom @sdetweil
                                    We are talking about this module, right?
                                    https://github.com/ianperrin/MMM-ModuleScheduler
                                    See the Scheduling Module Display part.
                                      sdetweil @evroom
                                      @evroom as I said, I had never seen that module before this discussion
                                      • evroomE
                                        evroom @sdetweil
                                        Okay, just that you commented on the scheduler part with “that only works for this one module…”.
                                        I thought you were familiar with this module.
                                        Sorry for the confusion :-)
                                        • evroomE
                                          evroom
                                          @Peter
                                          You can give MMM-soccer a try again.
                                          You should now see the standings.
                                          It has 1 major bug though, PSV is placed 1st and Ajax 2nd.
                                          This module is not so fancy as MMM-SoccerLiveScore, but I kind of liked the simplicity of it.
