Spotify module newbi
9 Posts 2 Posters 1.9k Views 2 Watching
    berne
    I just start my own bulding of a magic mirror, i am totley new to rpi, and alla codes and stuff. but i need son help, i am trying to install https://github.com/raywo/MMM-NowPlayingOnSpotify…
    but when i write cd moduel i get: cant find any files or folders
    i guess i have more deep in:S
    home/pi/MagicMirror/modules/defalut is what i have…
    so i sholde i write it to get it to work:/
      @berne said in Spotify module newbi:
      you should
      cd  /home/pi/MagicMirror/modules
      then
      git clone https://github.com/raywo/MMM-NowPlayingOnSpotify
      then
      cd MMM-NowPlayingOnSpotify
      does that work?
      B 1 Reply Last reply Jul 18, 2019, 11:29 AM Reply Quote 0
        berne @sdetweil
        @sdetweil said in Spotify module newbi:
        you should
        then
        then
        does that work?
        i works to the last part, it saying the same, no file or folder
        S 1 Reply Last reply Jul 18, 2019, 11:53 AM Reply Quote 0
          sdetweil @berne
          ok, from the MagicMirror/modules folder do
          ls
          it will list the folders and files…
          linux is case sensitive
          B 1 Reply Last reply Jul 18, 2019, 11:55 AM Reply Quote 0
            berne @sdetweil
            ls
            $ cd /home/pi/MagicMirror/modules
            pi@raspberrypi:~/MagicMirror/modules $ ls
            default MMM-NowPlayingonSpotify node_modules package-lock.json README.md
            EDIT: i can see all the files in /home/pi/MagicMirror/Moduels/MMM-NowPlayingSpotify
            EDIT2 pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $
            get the same result
            EDIT3
            i went to pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify and then write npm install. i think thaht works:S
              berne
              i@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $ npm install
              npm WARN deprecated socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
              npm notice created a lockfile as package-lock.json. You should commit this file.
              added 675 packages from 771 contributors and audited 4894 packages in 216.211s
              found 27 vulnerabilities (2 low, 5 moderate, 20 high)
              run npm audit fix to fix them, or npm audit for details
                berne
                98:11 error Parsing error: Unexpected token, expected ";" 96 | { 97 | module: "MMM-NowPlayingOnSpotify", > 98 | position: "top_left", | ^ 99 | 100 | config: { 101 | clientID: "431313e344ta464erfef3c0812323235c9232äå"
                When i now trying to boot MM , i cant find any config, if i have use the java liner to chek it, got this?
                S 1 Reply Last reply Jul 18, 2019, 3:44 PM Reply Quote 0
                  sdetweil @berne
                  @berne can u show us what you added to config… seems a missing comma probably
                  B 1 Reply Last reply Jul 18, 2019, 4:59 PM Reply Quote 0
                    berne @sdetweil
                    yes, u have done some thing i Home assistent, but this semms alot harder, when pasteing code, i did a new intall, Think i will do the spotify to morrow
