    Spotify module newbi
    9 Posts 2 Posters 2.3k Views 2 Watching
      berne
      I just start my own bulding of a magic mirror, i am totley new to rpi, and alla codes and stuff. but i need son help, i am trying to install https://github.com/raywo/MMM-NowPlayingOnSpotify…
      but when i write cd moduel i get: cant find any files or folders
      i guess i have more deep in:S
      home/pi/MagicMirror/modules/defalut is what i have…
      so i sholde i write it to get it to work:/
        @berne said in Spotify module newbi:
        you should
        cd  /home/pi/MagicMirror/modules
        then
        git clone https://github.com/raywo/MMM-NowPlayingOnSpotify
        then
        cd MMM-NowPlayingOnSpotify
        does that work?
          berne @sdetweil
          @sdetweil said in Spotify module newbi:
          you should
          then
          then
          does that work?
          i works to the last part, it saying the same, no file or folder
            sdetweil @berne
            ok, from the MagicMirror/modules folder do
            ls
            it will list the folders and files…
            linux is case sensitive
              berne @sdetweil
              ls
              $ cd /home/pi/MagicMirror/modules
              pi@raspberrypi:~/MagicMirror/modules $ ls
              default MMM-NowPlayingonSpotify node_modules package-lock.json README.md
              EDIT: i can see all the files in /home/pi/MagicMirror/Moduels/MMM-NowPlayingSpotify
              EDIT2 pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $
              get the same result
              EDIT3
              i went to pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify and then write npm install. i think thaht works:S
                berne
                i@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $ npm install
                npm WARN deprecated socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
                npm notice created a lockfile as package-lock.json. You should commit this file.
                added 675 packages from 771 contributors and audited 4894 packages in 216.211s
                found 27 vulnerabilities (2 low, 5 moderate, 20 high)
                run npm audit fix to fix them, or npm audit for details
                  berne
                  98:11 error Parsing error: Unexpected token, expected ";" 96 | { 97 | module: "MMM-NowPlayingOnSpotify", > 98 | position: "top_left", | ^ 99 | 100 | config: { 101 | clientID: "431313e344ta464erfef3c0812323235c9232äå"
                  When i now trying to boot MM , i cant find any config, if i have use the java liner to chek it, got this?
                    sdetweil @berne
                    @berne can u show us what you added to config… seems a missing comma probably
                      berne @sdetweil
                      yes, u have done some thing i Home assistent, but this semms alot harder, when pasteing code, i did a new intall, Think i will do the spotify to morrow
